求助各位大侠,我要疯掉了。。。。
2471|2
 楼主| henry144 发表于 2011-12-5 20:10 | 显示全部楼层 |阅读模式
LPC11系列控制ST7920的LCD,整了几天一直没有结果,时间来不及了,耗不下了,希望各位大侠帮忙,指出我的代码错误的地方。
单个命令能准确的显示,多个命令就不对了,多个数据也是乱码。。。。。小弟在此不胜感激啊!
#include "LPC11xx.h"                                                    /* LPC11xx外设寄存器            */
  宏定义
#define uchar                        unsigned char
#define uint                        unsigned int
#define LCD_EN_H                LPC_GPIO2->DATA |=(1<<0)
#define LCD_EN_L                LPC_GPIO2->DATA &=~(1<<0)
#define LCD_PSB_H                LPC_GPIO2->DATA |=(1<<1)
#define LCD_RS_H                LPC_GPIO2->DATA |=(1<<3)
#define LCD_RS_L                LPC_GPIO2->DATA &=~(1<<3)
#define LCD_RW_H                LPC_GPIO3->DATA |=(1<<2)
#define LCD_RW_L                LPC_GPIO3->DATA &=~(1<<2)
  全局变量
const unsigned char dis1[]={"1234567890"};
const unsigned char dis2[]={"你好!"};
** Function name:       myDelay
** Descriptions:        软件延时
** input parameters:    无
** output parameters:   无
** Returned value:      无
void Delay_1ms (uint n)
        uint i,j;
        j=0;
        i = 0;
    for(j=0;j<n;j++)
                for(i = 110;i > 0;i--);
void Delay_10us (uint n)
        uint i,j;
        j=0;
        i = 0;
    for(j=0;j<n;j++)
                for(i = 1;i > 0;i--);
** Function name:       GPIOInit
** Descriptions:        GPIO初始化
** output parameters:   P2.4~P2.11对应D0~D7
void GPIOInit( void )
    LPC_SYSCON->SYSAHBCLKCTRL |= (1 << 6);                              /* 初始化GPIO AHB时钟           */
    LPC_IOCON->PIO2_0 &= ~0x07;                                         /* 将P2.0-11初始化为GPIO功能    */
        LPC_IOCON->PIO2_1 &= ~0x07;
        LPC_IOCON->PIO2_3 &= ~0x07;
        LPC_IOCON->PIO2_4 &= ~0x07;
        LPC_IOCON->PIO2_5 &= ~0x07;
        LPC_IOCON->PIO2_6 &= ~0x07;
        LPC_IOCON->PIO2_7 &= ~0x07;
        LPC_IOCON->PIO2_8 &= ~0x07;
    LPC_IOCON->PIO2_9 &= ~0x07;
    LPC_IOCON->PIO2_10&= ~0x07;
    LPC_IOCON->PIO2_11&= ~0x07;
    LPC_GPIO2->DIR    |= 0xFFB ;                                     /* 将P2.0-11方向设置为输出      */
        LPC_IOCON->PIO3_2 &= ~0x07;
        LPC_GPIO3->DIR    |= (1 << 2);
void write_cmd(uchar cmd)
        uchar lcdtemp=0;
        LCD_RS_L;
        LCD_RW_H;
        LPC_GPIO2->DIR    &=~(0xFF<<4);
        do        //判忙
                LCD_EN_H;
                Delay_10us(1);
                lcdtemp |=LPC_GPIO2->DATA ;
                LCD_EN_L;
        while(lcdtemp&(0x80<<4));
        LCD_RW_L;
        LPC_GPIO2->DATA =(cmd<< 4);
        LCD_EN_H;
        Delay_1ms(5);
        LCD_EN_L;
void write_data(uchar data)
        uchar lcdtemp=0;
        LCD_RS_L;
        LCD_RW_H;
        do                                                        //判忙
                LCD_EN_H;
                Delay_10us(1);
                lcdtemp=LPC_GPIO2->DATA ;
                LCD_EN_L;
        LCD_RS_H;
        LCD_RW_L;
        LPC_GPIO2->DATA =(data<< 4);
        LCD_EN_H;
        Delay_1ms(5);
        LCD_EN_L;
void lcd_init()
        LCD_PSB_H;                                        //并行口方式
        write_cmd(0x30);                        //基本指令操作
        Delay_1ms(5);
        write_cmd(0x02);                        //地址归位
        Delay_1ms(5);
        write_cmd(0x0C);                        //显示开,光标关
        Delay_1ms(5);
        write_cmd(0x01);                        //清除LCD的显示内容
void main(void)
        uchar i;
        SystemInit();                                                   /* 初始化目标板,切勿删除       */
        GPIOInit();
        Delay_1ms(100);
        lcd_init();
  // while (1) {
                //write_cmd(0x0E);
                write_cmd(0x90);
                i=0;
                while(dis1!='\0')
                        write_data(dis1);
                        i++;
  End Of File
 楼主| henry144 发表于 2011-12-16 07:49 | 显示全部楼层
问题找到了,P2.0~P2.3作为控制信号,P2.4~P2.11作为数据总线,当使用左移<<时,低位补0,使得控制信号失效,所以不对。。。。
Thunder_f 发表于 2011-12-16 13:48 | 显示全部楼层
还是自己对自己的问题比较舍得花时间
