[运放] 额温枪首选高精度运放
1199|1
 楼主| rickluo 发表于 2020-2-28 23:28 | 显示全部楼层 |阅读模式
RS8551、RS8557
FEATURES
• Low Offset Voltage: 3uV
• Input Offset Drift: 0.03μV/°C
• High Gain Bandwidth Product: 4.3MHz
• Rail-to-Rail Input and Output
• High Gain, CMRR, PSRR:120dB
• High Slew Rate: 2.5V/μs • Low Noise: 0.93uVp-p (0.01~10Hz)
• Low Power Consumption: 650μA /op amp
• Overload Recovery Time:1us
• Low Supply Voltage: +2.7 V to +5.5 V
• No External Capacitors Required
• Extended Temperature: -40°C to +125°C
APPLICATIONS
• Temperature Sensors
• Medical/Industrial Instrumentation
• Pressure Sensors
• Battery-Powered Instrumentation
• Active Filtering
• Weight Scale Sensor
• Strain Gage Amplifiers
• Power Converter/Inverter
样品、技术支持,请联系:QQ1529637660
yanwen217 发表于 2020-2-29 13:17 | 显示全部楼层
要求原厂翻译成中文的资料吧
