[MCU] JTAG连接
1313|15
 楼主| llljh 发表于 2020-3-14 14:18 | 显示全部楼层 |阅读模式
仿真器型号设置是正确的,烧写的板子是官方HVPM电机用的控制板。还试着用其他两片自己按官方控制板改造的板子,结果还是一样的错误。
仿真器应该是没有问题的。
connection test 的内容如下:
[Start]
Execute the command:
%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\Users\zejian\AppData\Local\.TI\1879930773\
0\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 100- or 510-class product.
This utility will load the adapter 'jioserdesusbv3.dll'.
The library build date was 'Aug 20 2013'.
The library build time was '22:56:19'.
The library package version is '5.1.232.0'.
The library component version is '35.34.40.0'.
The controller does not use a programmable FPGA.
The controller has a version number of '4' (0x00000004).
The controller has an insertion length of '0' (0x00000000).
This utility will attempt to reset the controller.
This utility has successfully reset the controller.
-----[Print the reset-command hardware log-file]-----------------------------
The scan-path will be reset by toggling the JTAG TRST signal.
The controller is the FTDI FT2232 with USB interface.
The link from controller to target is direct (without cable).
The software is configured for FTDI FT2232 features.
The controller cannot monitor the value on the EMU[0] pin.
The controller cannot monitor the value on the EMU[1] pin.
The controller cannot control the timing on output pins.
The controller cannot control the timing on input pins.
The scan-path link-delay has been set to exactly '0' (0x0000).
An error occurred while hard opening the controller.
-----[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver or utilities.
The value is '-233' (0xffffff17).
The title is 'SC_ERR_PATH_BROKEN'.
The explanation is:
The JTAG IR and DR scan-paths cannot circulate bits, they may be broken.
An attempt to scan the JTAG scan-path has failed.
The target's JTAG scan-path appears to be broken
with a stuck-at-ones or stuck-at-zero fault.
[End]
不知道是什么问题
huwr 发表于 2020-3-14 14:23 | 显示全部楼层
使用的是什么仿真器?
chenho 发表于 2020-3-14 14:26 | 显示全部楼层
这个告警是在什么地方出现的?
dingy 发表于 2020-3-14 14:29 | 显示全部楼层
电脑是否识别了这个仿真器?
yinxiangh 发表于 2020-3-14 14:33 | 显示全部楼层
连接的时候还是仿真的时候?
zwll 发表于 2020-3-14 14:47 | 显示全部楼层
感觉像FT2232的配置模式了    类似于更新插件
 楼主| llljh 发表于 2020-3-14 14:51 | 显示全部楼层
这是在说硬件引起的问题的哈
 楼主| llljh 发表于 2020-3-14 14:54 | 显示全部楼层
使用的是XDS100v3
 楼主| llljh 发表于 2020-3-14 14:57 | 显示全部楼层
插上去的时候可以在设备管理器里面看到这个设备,应该是可以识别的
 楼主| llljh 发表于 2020-3-14 15:01 | 显示全部楼层
这个告警是在什么地方出现的?
CCS,调试的时候出现的
 楼主| llljh 发表于 2020-3-14 15:04 | 显示全部楼层
连接的时候还是仿真的时候?
点击调试的时候
 楼主| llljh 发表于 2020-3-14 15:18 | 显示全部楼层
什么意思??
有什么解决的办法吗
xxmmi 发表于 2020-3-14 15:21 | 显示全部楼层
首先接入仿真器   看看设备管理器下是否出现串口和JTAG两个设备
llia 发表于 2020-3-14 15:25 | 显示全部楼层
如果看到  说明仿真器基本没问题
huwr 发表于 2020-3-14 15:28 | 显示全部楼层
接下来就看CCS这边对仿真器的驱动支持了
 楼主| llljh 发表于 2020-3-14 15:35 | 显示全部楼层
我的问题解决了,这边是jtag线损坏,换了一根jtag线就能用了。
