5V/3A车充方案(CC/CV,OCP,OVP,SCP,CL,UVLO)
5423|1
 楼主| shenzhenic 发表于 2011-12-7 22:45 | 显示全部楼层 |阅读模式
5V/3A车充方案(CC/CV,OCP,OVP,SCP,CL,UVLO),可通过苹果EMI & TMC认证
PWM Control Controller for 5V/3A,5V/3.1-5A solution
10.AX3304/A-PWM Control Controller
AX3304/A-PWM Control Controller  DataSheet
AX3304(100Khz/300Khz) High Efficiency solution For  5V/3A 5V/3.1A solution
Vin : 8V~38V
* Freq=100Khz/300Khz
* Build in Line compensate +OCP+OVP function
* Supply CC / CV for Li-on battery charger mode
* EMI & TMC Approval available
FEATURES
- Input voltage:8V to 38V
- Duty ratio:0% to 100% PWM control
- Oscillation frequency:100K/300KHz
- Thermal Shutdown function.
- Short Circuit Protect (SCP).
- External SW P-channel MOS.
- External OVP setting function.
- Current mode non-synchronous PWM converter
- External current limit setting.
- Under voltage Lockout.
- SOP-8L Pb-Free package.
tianm 发表于 2011-12-9 11:04 | 显示全部楼层
AXElite 的网站上连PDF都下不到
个人签名:微桥科技 Tel:0755-83991588 QQ:4221620,7125313 www.micro-bridge.com 电源管理IC(DC-DC,AC-DC,LED驱动,LDO,音频功放,锂电充电,MOSFET)
