第一期评估板驱动HT1621
1533|4
 楼主| Cjy_JDxy 发表于 2020-3-22 11:35 | 显示全部楼层 |阅读模式
我申请的AVR小板换成PIC18了。
今天搞了一下HT1621
代码如下:
// CONFIG1L
#pragma config FEXTOSC = ECH    // External Oscillator mode Selection bits (EC (external clock) above 8 MHz; PFM set to high power)
#pragma config RSTOSC = EXTOSC  // Power-up default value for COSC bits (EXTOSC operating per FEXTOSC bits (device manufacturing default))
// CONFIG1H
#pragma config CLKOUTEN = OFF   // Clock Out Enable bit (CLKOUT function is disabled)
#pragma config CSWEN = ON       // Clock Switch Enable bit (Writing to NOSC and NDIV is allowed)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor enabled)
// CONFIG2L
#pragma config MCLRE = EXTMCLR  // Master Clear Enable bit (MCLR pin (RE3) is MCLR)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (Power up timer disabled)
#pragma config LPBOREN = OFF    // Low-power BOR enable bit (Low power BOR is disabled)
#pragma config BOREN = SBORDIS  // Brown-out Reset Enable bits (Brown-out Reset enabled , SBOREN bit is ignored)
// CONFIG2H
#pragma config BORV = VBOR_190  // Brown Out Reset Voltage selection bits (Brown-out Reset Voltage (VBOR) set to 1.90V)
#pragma config ZCD = OFF        // ZCD Disable bit (ZCD disabled. ZCD can be enabled by setting the ZCDSEN bit of ZCDCON)
#pragma config PPS1WAY = ON     // PPSLOCK bit One-Way Set Enable bit (PPSLOCK bit can be cleared and set only once; PPS registers remain locked after one clear/set cycle)
#pragma config STVREN = ON      // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Extended Instruction Set and Indexed Addressing Mode disabled)
// CONFIG3L
#pragma config WDTCPS = WDTCPS_31// WDT Period Select bits (Divider ratio 1:65536; software control of WDTPS)
#pragma config WDTE = OFF       // WDT operating mode (WDT Disabled)
// CONFIG3H
#pragma config WDTCWS = WDTCWS_7// WDT Window Select bits (window always open (100%); software control; keyed access not required)
#pragma config WDTCCS = SC      // WDT input clock selector (Software Control)
// CONFIG4L
#pragma config WRT0 = OFF       // Write Protection Block 0 (Block 0 (000800-003FFFh) not write-protected)
#pragma config WRT1 = OFF       // Write Protection Block 1 (Block 1 (004000-007FFFh) not write-protected)
#pragma config WRT2 = OFF       // Write Protection Block 2 (Block 2 (008000-00BFFFh) not write-protected)
#pragma config WRT3 = OFF       // Write Protection Block 3 (Block 3 (00C000-00FFFFh) not write-protected)
#pragma config WRT4 = OFF       // Write Protection Block 4 (Block 4 (010000-013FFFh) not write-protected)
#pragma config WRT5 = OFF       // Write Protection Block 5 (Block 5 (014000-017FFFh) not write-protected)
#pragma config WRT6 = OFF       // Write Protection Block 6 (Block 6 (018000-01BFFFh) not write-protected)
#pragma config WRT7 = OFF       // Write Protection Block 7 (Block 7 (01C000-01FFFFh) not write-protected)
// CONFIG4H
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration registers (300000-30000Bh) not write-protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
#pragma config WRTD = OFF       // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
#pragma config SCANE = ON       // Scanner Enable bit (Scanner module is available for use, SCANMD bit can control the module)
#pragma config LVP = ON         // Low Voltage Programming Enable bit (Low voltage programming enabled. MCLR/VPP pin function is MCLR. MCLRE configuration bit is ignored)
// CONFIG5L
#pragma config CP = OFF         // UserNVM Program Memory Code Protection bit (UserNVM code protection disabled)
#pragma config CPD = OFF        // DataNVM Memory Code Protection bit (DataNVM code protection disabled)
// CONFIG5H
// CONFIG6L
#pragma config EBTR0 = OFF      // Table Read Protection Block 0 (Block 0 (000800-003FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF      // Table Read Protection Block 1 (Block 1 (004000-007FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF      // Table Read Protection Block 2 (Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF      // Table Read Protection Block 3 (Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks)
#pragma config EBTR4 = OFF      // Table Read Protection Block 4 (Block 4 (010000-013FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR5 = OFF      // Table Read Protection Block 5 (Block 5 (014000-017FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR6 = OFF      // Table Read Protection Block 6 (Block 6 (018000-01BFFFh) not protected from table reads executed in other blocks)
#pragma config EBTR7 = OFF      // Table Read Protection Block 7 (Block 7 (01C000-01FFFFh) not protected from table reads executed in other blocks)
// CONFIG6H
#pragma config EBTRB = OFF      // Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#include <pic18f47q10.h>
#define Smg_a    0x80
#define Smg_b    0x40
#define Smg_c    0x20
#define Smg_d    0x01
#define Smg_e    0x02
#define Smg_f    0x08
#define Smg_g    0x04
#define Smg_dp   0x10
#define Bmp0Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
#define Bmp1Map          Smg_b | Smg_c
#define Bmp2Map          Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
#define Bmp3Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
#define Bmp4Map          Smg_b | Smg_c | Smg_f | Smg_g
#define Bmp5Map          Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp6Map          Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp8Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp9Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp7Map          Smg_a | Smg_b | Smg_c
#define BmpAMap          Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
#define BmpBMap          Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpCMap          Smg_a | Smg_d | Smg_e | Smg_f
#define BmpDMap          Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
#define BmpEMap          Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpFMap          Smg_a | Smg_e | Smg_f | Smg_g
#define CS_0           RD0=0
#define CS_1           RD0=1
#define WR_0           RD1=0
#define WR_1           RD1=1
#define DA_0           RD2=0
#define DA_1           RD2=1
#define DELAYCONST 3
const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //显示缓冲区
//unsigned int i;
void delay(unsigned char x)
    unsigned char i;
    for(i=x;i>0;i--);
void COMMAND_HT1621(unsigned char comm)
unsigned char i;
CS_0;
delay(DELAYCONST);
WR_0;
    delay(DELAYCONST);
for(i=0;i<3;i++)        //写命令
  if((0x04<<i)&0x04)  DA_1;    //100
  else                DA_0;
        delay(DELAYCONST);
  WR_0;
        delay(DELAYCONST);
  WR_1;
        delay(DELAYCONST);
for(i=0;i<9;i++)        //写命令数据
  if((comm<<i)&0x80)  DA_1;    //100
  else                DA_0;
        delay(DELAYCONST);
  WR_0;
        delay(DELAYCONST);
  WR_1;
        delay(DELAYCONST);
CS_1;
void HT1621_Display(void)
unsigned char i;
CS_0;                        //片选CS
    delay(DELAYCONST);
WR_0;
    delay(DELAYCONST);
  if((0x05<<i)&0x04)  DA_1;
  else                DA_0;
        delay(DELAYCONST);
  WR_0;
        delay(DELAYCONST);
  WR_1;
        delay(DELAYCONST);
for(i=0;i<6;i++)                   //写地址
  if((20<<i)&0x20)    DA_1;  //20对应 SEG地址
    else                DA_0;
        delay(DELAYCONST);
  WR_0;
        delay(DELAYCONST);
  WR_1;
        delay(DELAYCONST);
for(i=0;i<8;i++)                   //写数据
  if((DpyNum[5]<<i)&0x80)   DA_1;
  else                      DA_0;
  delay(DELAYCONST);
  WR_0;
        delay(DELAYCONST);
  WR_1;
        delay(DELAYCONST);
  if((DpyNum[4]<<i)&0x80)   DA_1;
  else                      DA_0;
  delay(DELAYCONST);
  WR_0;
        delay(DELAYCONST);
  WR_1;
        delay(DELAYCONST);
  if((DpyNum[3]<<i)&0x80)   DA_1;
  else                      DA_0;
  delay(DELAYCONST);
  WR_0;
        delay(DELAYCONST);
  WR_1;
        delay(DELAYCONST);
  if((DpyNum[2]<<i)&0x80)   DA_1;
  else                      DA_0;
  delay(DELAYCONST);
  WR_0;
        delay(DELAYCONST);
  WR_1;
        delay(DELAYCONST);
  if((DpyNum[1]<<i)&0x80)   DA_1;
  else                      DA_0;
  delay(DELAYCONST);
  WR_0;
        delay(DELAYCONST);
  WR_1;
        delay(DELAYCONST);
  if((DpyNum[0]<<i)&0x80)   DA_1;
  else                      DA_0;
  delay(DELAYCONST);
  WR_0;
        delay(DELAYCONST);
  WR_1;
        delay(DELAYCONST);
CS_1;                          //释放CS
void LCD_Init(void)
COMMAND_HT1621(0x01);         //SYS EN
COMMAND_HT1621(0x03);         //LCD ON
COMMAND_HT1621(0x29);         //4 COM  1/3 BIAS
HT1621_Display();             //clear screen
void main(void)
    TRISD=0;
    ANSELD=0;
    ODCOND=0;
    SLRCOND=0;
    ADCON0=0;
    //WPUE=0x04;
    LCD_Init();
    DpyNum[0] = Smg_a|Smg_d|Smg_g;              //"三"
    DpyNum[1] = SegCode[1];
    DpyNum[2] = SegCode[3];
    DpyNum[3] = SegCode[5];
    DpyNum[4] = SegCode[7];
    DpyNum[5] = SegCode[9];
    HT1621_Display();               //刷新LCD
    while(1)
    return;
效果图:
formation 发表于 2020-3-22 11:49 | 显示全部楼层
感谢楼主分享!很赞。刚看到别的好像AVR的板也被换成PIC了
 楼主| Cjy_JDxy 发表于 2020-3-22 11:57 | 显示全部楼层
21ic小喇叭 发表于 2020-3-23 08:36 | 显示全部楼层
感谢分享!
奖励您2000家园币,这是论坛新出的功能,可以兑换奖品或抽奖
感谢您的宝贵分享!
labasi 发表于 2020-4-2 16:23 | 显示全部楼层
非常感谢楼主分享
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
