Nand 设备中断
- void HAL_NAND_IRQHandler(NAND_HandleTypeDef *hnand)
- /* Check NAND interrupt Rising edge flag */
- if(__FMC_NAND_GET_FLAG(hnand->Instance, hnand->Init.NandBank, FMC_FLAG_RISING_EDGE))
- /* NAND interrupt callback*/
- HAL_NAND_ITCallback(hnand);
- /* Clear NAND interrupt Rising edge pending bit */
- __FMC_NAND_CLEAR_FLAG(hnand->Instance, FMC_FLAG_RISING_EDGE);
- /* Check NAND interrupt Level flag */
- if(__FMC_NAND_GET_FLAG(hnand->Instance, hnand->Init.NandBank, FMC_FLAG_LEVEL))
- /* Clear NAND interrupt Level pending bit */
- __FMC_NAND_CLEAR_FLAG(hnand->Instance, FMC_FLAG_LEVEL);
- /* Check NAND interrupt Falling edge flag */
- if(__FMC_NAND_GET_FLAG(hnand->Instance, hnand->Init.NandBank, FMC_FLAG_FALLING_EDGE))
- /* Clear NAND interrupt Falling edge pending bit */
- __FMC_NAND_CLEAR_FLAG(hnand->Instance, FMC_FLAG_FALLING_EDGE);
- /* Check NAND interrupt FIFO empty flag */
- if(__FMC_NAND_GET_FLAG(hnand->Instance, hnand->Init.NandBank, FMC_FLAG_FEMPT))
- /* Clear NAND interrupt FIFO empty pending bit */
- __FMC_NAND_CLEAR_FLAG(hnand->Instance, FMC_FLAG_FEMPT);
