[技术问答] N76E003 Timer0/1 Mode1 demo code
537|5
 楼主| darklighttt 发表于 2020-3-30 19:37 | 显示全部楼层 |阅读模式
  1. /*---------------------------------------------------------------------------------------------------------*/
  2. /*        */
  3. /* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
  4. /*        */
  5. /*---------------------------------------------------------------------------------------------------------*/
  6. //***********************************************************************************************************
  7. //  Nuvoton Technoledge Corp.
  8. //  Website: http://www.nuvoton.com
  9. //  E-Mail : MicroC-8bit@nuvoton.com
  10. //  Date   : Apr/21/2017
  11. //***********************************************************************************************************
  12. //***********************************************************************************************************
  13. //  File Function: N76E003 Timer0/1 Mode1 demo code
  14. //***********************************************************************************************************
  15. #include "N76E003.h"
  16. #include "Common.h"
  17. #include "Delay.h"
  18. #include "SFR_Macro.h"
  19. #include "Function_define.h"
  20. //*****************  The Following is in define in Fucntion_define.h  ***************************
  21. //****** Always include Function_define.h call the define you want, detail see main(void) *******
  22. //***********************************************************************************************
  23. #if 0
  24. //#define                TIMER0_MODE0_ENABLE                TMOD&=0x0F
  25. //#define                TIMER0_MODE1_ENABLE                TMOD&=0x0F;TMOD|=0x10
  26. //#define                TIMER0_MODE2_ENABLE                TMOD&=0x0F;TMOD|=0x20
  27. //#define                TIMER0_MODE3_ENABLE                TMOD&=0x0F;TMOD|=0x3F
  28. //#define                TIMER1_MODE0_ENABLE                TMOD&=0xF0
  29. //#define                TIMER1_MODE1_ENABLE                TMOD&=0xF0;TMOD|=0x01
  30. //#define                TIMER1_MODE2_ENABLE                TMOD&=0xF0;TMOD|=0x02
  31. //#define                TIMER1_MODE3_ENABLE                TMOD&=0xF0;TMOD|=0xF3
  32. #endif
  33. #define TH0_INIT        50000
  34. #define TL0_INIT        50000
  35. #define TH1_INIT        25000
  36. #define TL1_INIT        25000
  37. UINT8 u8TH0_Tmp,u8TL0_Tmp,u8TH1_Tmp,u8TL1_Tmp;
  38. /************************************************************************************************************
  39. *    TIMER 0 interrupt subroutine
  40. ************************************************************************************************************/
  41. void Timer0_ISR (void) interrupt 1  //interrupt address is 0x000B
  42. {
  43.     TH0 = u8TH0_Tmp;
  44.     TL0 = u8TL0_Tmp;
  45.
  46.     P12 = ~P12;                     // GPIO1 toggle when interrupt
  47. }
  48. /************************************************************************************************************
  49. *    TIMER 1 interrupt subroutine
  50. ************************************************************************************************************/
  51. void Timer1_ISR (void) interrupt 3  //interrupt address is 0x001B
  52. {
  53.     TH1 = u8TH1_Tmp;
  54.     TL1 = u8TL1_Tmp;
  55.     P03 = ~P03;                     //P0.3 toggle when interrupt
  56. }
  57. /************************************************************************************************************
  58. *    Main function
  59. ************************************************************************************************************/
  60. void main (void)
  61. {
  62.
  63.     Set_All_GPIO_Quasi_Mode;
  64.                 TIMER0_MODE1_ENABLE;
  65.                 TIMER1_MODE1_ENABLE;
  66.     clr_T1M;
  67.     //set_T1M;
  68.     u8TH0_Tmp = (65536-TH0_INIT)/256;
  69.     u8TL0_Tmp = (65536-TL0_INIT)%256;
  70.     u8TH1_Tmp = (65536-TH1_INIT)/256;
  71.     u8TL1_Tmp = (65536-TL1_INIT)%256;
  72.
  73.     TH0 = u8TH0_Tmp;
  74.     TL0 = u8TL0_Tmp;
  75.     TH1 = u8TH1_Tmp;
  76.     TL1 = u8TL1_Tmp;
  77.
  78.     set_ET0;                                    //enable Timer0 interrupt
  79.     set_ET1;                                    //enable Timer1 interrupt
  80.     set_EA;                                     //enable interrupts
  81.     set_TR0;                                    //Timer0 run
  82.     set_TR1;                                    //Timer1 run
  83.     while(1);
  84. }
八层楼 发表于 2020-4-6 15:56 | 显示全部楼层
非常感谢楼主分享
观海 发表于 2020-4-6 15:57 | 显示全部楼层
非常感谢楼主分享
guanjiaer 发表于 2020-4-6 15:57 | 显示全部楼层
非常感谢楼主分享
heimaojingzhang 发表于 2020-4-6 15:57 | 显示全部楼层
非常感谢楼主分享
keaibukelian 发表于 2020-4-6 15:57 | 显示全部楼层
非常感谢楼主分享
