[资料分享] 功耗优化型 77GHz 液位变送器参考设计 TIDEP-0091
1444|16
 楼主| dirtwillfly 发表于 2020-3-31 21:26 | 显示全部楼层 |阅读模式
描述
TI Design TIDEP-0091 highlights strategies for power optimization of IWR14xx 76- to 81-GHz mmWave sensors in tank level-probing applications, displacement sensors, 4- to 20-mA sensors, and other low-power applications for detecting range with high accuracy in a minimal power envelope. In these applications, the system often operates on a low-voltage data line that provides less power than the operational power consumption. Duty cycling is critical to reducing the average power to meet the power input restrictions. Power optimization is achieved through MSP432 external duty cycling the IWR14xx device for periodic sensing. Additionally, this TI Design provides a sample configuration for single-dimensional range detection.
Read more about fluid-level sensing using 77-GHz millimeter wave (SPYY004).
Watch the introduction to level sensing (video).
特性
  • Uses IWR1443 mmWave and SimpleLink MSP432 software development kits (SDKs)
  • Serial communication between IWR1443 and MSP432
  • Provides an optimized processing chain for single-dimension range detection
  • Applicable to any application requiring low-power duty cycling
 楼主| dirtwillfly 发表于 2020-3-31 21:28 | 显示全部楼层
功耗优化型 IWR1443 77GHz 液位变送器参考设计 (Rev. B).pdf (4.25 MB, 下载次数: 3)
wiba 发表于 2020-4-2 13:23 | 显示全部楼层
非常感谢楼主分享
zljiu 发表于 2020-4-2 13:24 | 显示全部楼层
非常感谢楼主分享
coshi 发表于 2020-4-2 13:24 | 显示全部楼层
非常感谢楼主分享
aoyi 发表于 2020-4-2 13:24 | 显示全部楼层
非常感谢楼主分享
drer 发表于 2020-4-2 13:24 | 显示全部楼层
非常感谢楼主分享
 楼主| dirtwillfly 发表于 2020-6-22 17:25 | 显示全部楼层
Fluid-Level Sensing using 77GHz millimeter wave.pdf (818.52 KB, 下载次数: 0)
 楼主| dirtwillfly 发表于 2020-6-22 17:27 | 显示全部楼层
Chirp Budget Calc_09_25_18.zip (53.98 KB, 下载次数: 0)
Chirp Budget Calc_09_10_18.zip (52.97 KB, 下载次数: 0)
 楼主| dirtwillfly 发表于 2020-6-22 17:29 | 显示全部楼层
Power Optimization for 77GHz Level Transmitter BOM.pdf (73.22 KB, 下载次数: 0)
 楼主| dirtwillfly 发表于 2020-6-22 17:30 | 显示全部楼层
Power Optimization for 77GHz Level Transmitter Schematic and Block Diagram.pdf (575.19 KB, 下载次数: 0)
 楼主| dirtwillfly 发表于 2020-6-22 17:31 | 显示全部楼层
Power Optimization for 77GHz Level Transmitter Altium.zip (513.53 KB, 下载次数: 0)
 楼主| dirtwillfly 发表于 2020-6-22 17:32 | 显示全部楼层
Power Optimization for 77GHz Level Transmitter Gerber.zip (2.2 MB, 下载次数: 0)
Power Optimization for 77GHz Level Transmitter Layer Plots.zip (4.08 MB, 下载次数: 0)
 楼主| dirtwillfly 发表于 2020-6-22 17:33 | 显示全部楼层
Power Optimization for 77GHz Level Transmitter Assembly Files.zip (352.51 KB, 下载次数: 0)
 楼主| dirtwillfly 发表于 2020-6-22 17:35 | 显示全部楼层
Power Optimized Level Sensing Demo Software.zip (12.18 MB, 下载次数: 0)
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1203
