[资料分享] 12mm x 12mm、5 轨应用处理器电源定序参考设计 TIDA-01568
959|11
 楼主| dirtwillfly 发表于 2020-3-31 21:50 | 显示全部楼层 |阅读模式
描述
This reference design demonstrates a validated and cost competitive power sequencing solution for an application processor or a high performance control platform. This design supports 5 different voltage rails, optimized with layout space of 12 mm × 12 mm. The design is also capable of adjusting delay time and re-configuring specific voltage level for each rail to fit different input capacitors and different processors' requirements.
特性
  • Validated power sequencing solution for application processors
  • Correct power up/down sequence, even for uncontrolled power off at various load situations
  • Power tree efficiency is maintained high both at heavy load and at a light load
  • Small layout space of power supply: area smaller than 12 mm × 12 mm
 楼主| dirtwillfly 发表于 2020-3-31 21:51 | 显示全部楼层
12mm × 12mm、5 轨电源定序参考设计.pdf (1.77 MB, 下载次数: 1)
drer 发表于 2020-4-2 13:33 | 显示全部楼层
非常感谢楼主分享
gwsan 发表于 2020-4-2 13:33 | 显示全部楼层
非常感谢楼主分享
kxsi 发表于 2020-4-2 13:33 | 显示全部楼层
非常感谢楼主分享
nawu 发表于 2020-4-2 13:34 | 显示全部楼层
非常感谢楼主分享
qcliu 发表于 2020-4-2 13:34 | 显示全部楼层
非常感谢楼主分享
shakencity 发表于 2020-4-7 14:48 | 显示全部楼层
学习学习 非常感谢楼主分享
 楼主| dirtwillfly 发表于 2020-7-2 22:24 | 显示全部楼层
TIDA-01568 Assembly Drawing (Bottom View).pdf (565.74 KB, 下载次数: 0)
 楼主| dirtwillfly 发表于 2020-7-2 22:25 | 显示全部楼层
TIDA-01568 BOM.pdf (41.87 KB, 下载次数: 0)
 楼主| dirtwillfly 发表于 2020-7-2 22:51 | 显示全部楼层
TIDA-01568 CAD Files.zip (2.79 MB, 下载次数: 0)
 楼主| dirtwillfly 发表于 2020-7-2 23:38 | 显示全部楼层
TIDA-01568 Assembly Drawing.pdf (578.13 KB, 下载次数: 0)
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1200
