关于STM32F103C USART启动模式进入bootloader的问题
592|1
 楼主| 社畜一枚 发表于 2020-4-3 21:43 | 显示全部楼层 |阅读模式
最近在尝试用STM32F103C板USART模式进入Flash bootloader,刷新的程序,遇到了芯片没法初始化的问题,
试了3个不同的工具包括STM32官方的STM32 flash loader,请问各位大佬有遇到过这样的问题么?
怀疑是不是内部bootloader的程序对PL2303 转换卡不太兼容啊?谢谢!
具体如下:
root@bogon stm32loader]# python3 main.py  -p /dev/ttyUSB0 -V
Open port /dev/ttyUSB0, baud 115200
Activating bootloader (select UART)
Bootloader activation timeout -- retrying
Can't init into bootloader. Ensure that BOOT0 is enabled and reset the device.
我使用的RS232 TTL converter 为: usb 2-2.2: pl2303 converter now attached to ttyUSB0),
硬件连接为 : "RXD -PA9, TXD-PA10, GND-G", 上电用 USB 5V, 板载regulator转 3.3V.
我的测试环境:Centos 6.5, the status for PL2303 is :
Device: /dev/ttyUSB0
Signal  Pin  Pin  Direction  Status  Full
Name    (25) (9)  (computer)         Name
FG         1    -      -           -   Frame Ground
TxD         2    3      out         -   Transmit Data
RxD         3    2      in          -   Receive  Data
RTS         4    7      out         1   Request To Send
CTS         5    8      in          0   Clear To Send
DSR         6    6      in          0   Data Set Ready
GND         7    5      -           -   Signal Ground
DCD         8    1      in          0   Data Carrier Detect
DTR     20    4      out         1   Data Terminal Ready
RI        22    9      in          0   Ring Indicator
在windows下也尝试了用 FlyMCU, 上电后返回全是 0x00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
芯片超时无应答,无法连接
使用STM32 官方的工具也是一样
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\Arduino_STM32-master\tools\win>stm32flash.exe -k COM7
stm32flash 0.4
http://stm32flash.googlecode.com/
Interface serial_w32: 57600 8E1
Failed to init device.
zchong 发表于 2020-4-4 09:16 | 显示全部楼层
了解下载过程,监控串口数据,徐徐图之,只是从不能下载判断,那可能的原因太多太多了
