[C语言]
有熟悉大金空调hBS协议的校验码
2136|12
哪位能看出最后的校验码?重金求谢!私聊也可以。这个是短码
00 00 20 04 3C
00 01 20 04 6D
00 02 20 04 9E
00 03 20 04 CF
00 04 20 04 CB
00 05 20 04 9A
00 06 20 04 69
00 07 20 04 38
00 08 20 04 61
00 09 20 04 30
00 0A 20 04 C3
00 0B 20 04 92
00 0C 20 04 96
00 0D 20 04 C7
00 0E 20 04 34
00 0F 20 04 65
00 10 20 04 86
shkhlove|  楼主 | 2020-4-20 14:13 | 只看该作者
还有一个长码的,这是监控的大金P板(线控器)上的数据
00 00 10 00 62 02 10 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 57
00 00 10 00 62 02 11 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 3F
00 00 10 00 62 02 12 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 87
00 00 10 00 62 02 13 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 EF
00 00 10 00 62 02 14 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 44
00 00 10 00 62 02 15 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 2C
00 00 10 00 62 02 16 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 94
00 00 10 00 62 02 17 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 FC
00 00 10 00 62 02 18 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 71
00 00 10 00 62 02 19 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 19
00 00 10 00 62 02 1A 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 A1
00 00 10 00 62 02 1B 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 C9
00 00 10 00 62 02 1C 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 62
00 00 10 00 62 02 1D 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 0A
00 00 10 00 62 02 1E 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 B2
00 00 10 00 62 02 1F 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 DA
00 00 10 00 62 02 20 00 14 00 02 00 00 00 00 00 80 40 00 00 00 00 00 83
40 00 10 00 00 62 02 10 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 39
40 00 10 00 00 62 02 11 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 E0
40 00 10 00 00 62 02 12 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 38
40 00 10 00 00 62 02 13 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 E1
40 00 10 00 00 62 02 14 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 3B
40 00 10 00 00 62 02 15 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 E2
40 00 10 00 00 62 02 16 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 3A
40 00 10 00 00 62 02 17 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 E3
40 00 10 00 00 62 02 18 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 3D
40 00 10 00 00 62 02 19 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 E4
40 00 10 00 00 62 02 1A 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 3C
40 00 10 00 00 62 02 1B 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 E5
40 00 10 00 00 62 02 1C 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 3F
40 00 10 00 00 62 02 1D 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 E6
40 00 10 00 00 62 02 1E 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 3E
40 00 10 00 00 62 02 1F 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 E7
40 00 10 00 00 62 02 20 00 14 00 3A 00 00 00 00 00 80 00 00 00 00 00 21
飞翔的龙 2020-7-31 15:24 回复TA
列害!搞出来了吗、
菠菠菠菠菠菜| | 2020-4-20 14:29 | 只看该作者
帮顶  另想了解一下 你们用的HBUS芯片是美上美的?
shkhlove|  楼主 | 2020-4-20 15:00 | 只看该作者
mS1192
菠菠菠菠菠菜| | 2020-4-20 15:03 | 只看该作者
哈哈 原来是我们的产品  您这边是杭州的?
shkhlove|  楼主 | 2020-4-20 15:09 | 只看该作者
不是,项目还没成呢,搞了块板,用的这个芯片。校验这块能不能给点支持
菠菠菠菠菠菜| | 2020-4-20 15:13 | 只看该作者
shkhlove 发表于 2020-4-20 15:09
不是,项目还没成呢,搞了块板,用的这个芯片。校验这块能不能给点支持 ...
您加一下我微信吧 13175119321
shkhlove|  楼主 | 2020-4-20 15:21 | 只看该作者
已加,通过下
北极熊XXX| | 2022-2-17 11:27 | 只看该作者
01000011011010000000110101110000100000000001
00100100001000000000010010000001100000000001
00000000001000000000010000000000100000000001
00000000111 00000001011 01000000011 00000000001
02 00 00 00 00 00 80 40 01 设置热风模式
02 00 00 00 00 00 80 40 01 设置出风模式
02 00 00 00 00 00 80 40 01 设置空调自动模式
02 00 00 00 00 01 80 40 01 设置空调制冷模式
日本homebus协议
根据波形截取部分数据,有出风温湿度,回风温湿度,空调多模式设置等等也可以算校验
论坛不经常逛,可以QQ:2648152754
cdsc| | 2022-5-15 17:10 | 只看该作者
你们抓的数据是对的,和我计算出来校验码一模一样,需要交流加wangzb1030
cdsc| | 2022-6-17 19:51 | 只看该作者
我们自研设备已经可以集中控制多种空调了。这个图片是日立的控制截图。
