DAC输出两路正弦波 (600Hz)(2100Hz)改的官方的例程
698|0
 楼主| 3月的尾巴 发表于 2020-4-20 23:50 | 显示全部楼层 |阅读模式
  * @file    bsp_xxx.c
  * @author  fire
  * @version V1.0
  * @date    2013-xx-xx
  * @brief   adc1 应用bsp / DMA 模式
  * @attention
  * 实验平台:秉火STM32 霸道 开发板
  * 论坛    :http://www.firebbs.cn
  * 淘宝    :http://fire-stm32.taobao.com
#include "./dac/bsp_dac.h"
//正弦波单个周期的点数
//#define POINT_NUM 32
///* 波形数据 ---------------------------------------------------------*/
//const uint16_t Sine12bit[POINT_NUM] = {
//        2048        , 2460        , 2856        , 3218        , 3532        , 3786        , 3969        , 4072        ,
//        4093        , 4031        , 3887        , 3668        , 3382        , 3042        ,        2661        , 2255        ,
//        1841        , 1435        , 1054        , 714                , 428                , 209                , 65                , 3                        ,
//        24                , 127                , 310                , 564                , 878                , 1240        , 1636        , 2048
#define POINT_NUM 128
2148,2249,2349,2448,2546,2643,2738,2832,2924,3013,3101,
        3186,3268,3347,3423,3496,3565,3631,3693,3751,3805,3854,
        3899,3940,3976,4008,4035,4057,4074,4086,4094,4095,4094,
        4086,4074,4057,4035,4008,3976,3940,3899,3854,3805,3751,
        3693,3631,3565,3496,3423,3347,3268,3186,3101,3013,2924,
        2832,2738,2643,2546,2448,2349,2249,2148,2048,1948,1847,
        1747,1648,1550,1453,1358,1264,1172,1083,995,910,828,749,
        673,600,531,465,403,345,291,242,197,156,120,88,61,39,22,
        10,2,0,2,10,22,39,61,88,120,156,197,242,291,345,403,465,531,
        600,673,749,828,910,995,1083,1172,1264,1358,1453,1550,1648,
        1747,1847,1948,2048};
uint32_t DualSine12bit[POINT_NUM];
  * @brief  使能DAC的时钟,初始化GPIO
  * @param  无
  * @retval 无
static void DAC_Config(void)
        DAC_InitTypeDef  DAC_InitStructure;
  /* 使能GPIOA时钟 */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        /* 使能DAC时钟 */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
  /* DAC的GPIO配置,模拟输入 */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_4 | GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* 配置DAC 通道1 */
  DAC_InitStructure.DAC_Trigger = DAC_Trigger_T2_TRGO;                                                //使用TIM2作为触发源
  DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;        //不使用波形发生器
  DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable;        //不使用DAC输出缓冲
  DAC_Init(DAC_Channel_1, &DAC_InitStructure);
  /* 配置DAC 通道2 */
        DAC_InitStructure.DAC_Trigger = DAC_Trigger_T4_TRGO;                                                //使用TIM2作为触发源
  DAC_Init(DAC_Channel_2, &DAC_InitStructure);
  /* 使能通道1 由PA4输出 */
  DAC_Cmd(DAC_Channel_1, ENABLE);
  /* 使能通道2 由PA5输出 */
  DAC_Cmd(DAC_Channel_2, ENABLE);
  /* 使能DAC的DMA请求 */
        DAC_DMACmd(DAC_Channel_1, ENABLE);
  DAC_DMACmd(DAC_Channel_2, ENABLE);
  * @brief  配置TIM
  * @param  无
  * @retval 无
static void DAC_TIM2_Config(void)
        TIM_TimeBaseInitTypeDef    TIM_TimeBaseStructure;
        /* 使能TIM2时钟,TIM2CLK 为72M */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  /* TIM2基本定时器配置 */
// TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  TIM_TimeBaseStructure.TIM_Period = (938-1);        //定时600Hz
  TIM_TimeBaseStructure.TIM_Prescaler = 0x0;                                                               //预分频,不分频 72M / (0+1) = 72M
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;                                                    //时钟分频系数
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;          //向上计数模式
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  /* 配置TIM2触发源 */
  TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update);
        /* 使能TIM2 */
  TIM_Cmd(TIM2, ENABLE);
static void DAC_TIM4_Config(void)
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
  /* TIM2基本定时器配置 */
  TIM_TimeBaseStructure.TIM_Period = (268-1);        //定时2100Hz
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  /* 配置TIM2触发源 */
  TIM_SelectOutputTrigger(TIM4, TIM_TRGOSource_Update);
        /* 使能TIM2 */
  TIM_Cmd(TIM4, ENABLE);
  * @brief  配置DMA
  * @param  无
  * @retval 无
static void DAC_DMA2_Config(void)
        DMA_InitTypeDef  DMA_InitStructure;
        /* 使能DMA2时钟 */
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
        /* 配置DMA2 */
  DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_ADDRESS2;                        //外设数据地址
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&DualSine12bit ;                        //内存数据地址 DualSine12bit
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;                                                //数据传输方向内存至外设
  DMA_InitStructure.DMA_BufferSize = POINT_NUM;        //缓存大小为POINT_NUM字节
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;                        //外设数据地址固定
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                                        //内存数据地址自增
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;        //外设数据以字为单位
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;                        //内存数据以字为单位
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;                                                        //循环模式
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;                                                //高DMA通道优先级
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;        //非内存至内存模式
  DMA_Init(DMA2_Channel4, &DMA_InitStructure);
  /* 使能DMA2-14通道 */
  DMA_Cmd(DMA2_Channel4, ENABLE);
static void DAC_DMA1_Config(void)
        /* 使能DMA1时钟 */
        /* 配置DMA1 */
  DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_ADDRESS1;                        //外设数据地址
  DMA_Init(DMA2_Channel3, &DMA_InitStructure);
  /* 使能DMA2-14通道 */
  DMA_Cmd(DMA2_Channel3, ENABLE);
  * @brief  DAC初始化函数
  * @param  无
  * @retval 无
void DAC_Mode_Init(void)
        uint32_t Idx = 0;
        DAC_Config();
        DAC_TIM2_Config();
        DAC_TIM4_Config();
        /* 填充正弦波形数据,双通道右对齐*/
  for (Idx = 0; Idx < POINT_NUM; Idx++)
    DualSine12bit[Idx] = (Sine12bit[Idx] << 16) + (Sine12bit[Idx]);
        DAC_DMA2_Config();
        DAC_DMA1_Config();
