IIC读数据疑问:使能IIC清除EV6事件问题
609|0
冷冻链|  楼主 | 2020-4-25 10:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ev, iic, I2c, TE, AD
/* Clear EV6 by setting again the PE bit */
  I2C_Cmd(I2C1, ENABLE);
STM32 手册并未说  使能IIC  能够清楚 ADDR位 即EV6事件;
而是 失能IIC将由硬件清楚此位;
请大神解惑,不胜感激;
ADDR:地址已被发送(主模式)/地址匹配(从模式) (Address sent (master mode)/matched (slave mode))位1
在软件读取SR1寄存器后,对SR2寄存器的读操作将清除该位,或当PE=0时,由硬件清除该位。
完整函数如下:
void I2C_EE_BufferRead(u8* pBuffer, u8 ReadAddr, u16 NumByteToRead)
  //*((u8 *)0x4001080c) |=0x80;
    while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY)); // Added by Najoua 27/08/2008
  /* Send START condition */
  I2C_GenerateSTART(I2C1, ENABLE);
  //*((u8 *)0x4001080c) &=~0x80;
  /* Test on EV5 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
  /* Send EEPROM address for write */
  I2C_Send7bitAddress(I2C1, EEPROM_ADDRESS, I2C_Direction_Transmitter);
  /* Test on EV6 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
  /* Send the EEPROM's internal address to write to */
  I2C_SendData(I2C1, ReadAddr);
  /* Test on EV8 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
  /* Send STRAT condition a second time */
  /* Send EEPROM address for read */
  I2C_Send7bitAddress(I2C1, EEPROM_ADDRESS, I2C_Direction_Receiver);
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
  /* While there is data to be read */
  while(NumByteToRead)
    if(NumByteToRead == 1)
      /* Disable Acknowledgement */
      I2C_AcknowledgeConfig(I2C1, DISABLE);
      /* Send STOP Condition */
      I2C_GenerateSTOP(I2C1, ENABLE);
    /* Test on EV7 and clear it */
    if(I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED))
      /* Read a byte from the EEPROM */
      *pBuffer = I2C_ReceiveData(I2C1);
      /* Point to the next location where the byte read will be saved */
      pBuffer++;
      /* Decrement the read bytes counter */
      NumByteToRead--;
