[MCU]
寄存器的值不变
562|16
chuxh|  楼主 | 2020-4-25 19:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
void InitAdc(void)
        unsigned int i;
        AdcRegs.ADCTRL1.bit.RESET=1;
        NOP;
        AdcRegs.ADCTRL1.bit.RESET=0;
        AdcRegs.ADCTRL1.bit.SUSMOD=3;
        //仿真暂停时,序列发生器和其他数字电路逻辑立即停止
        AdcRegs.ADCTRL1.bit.ACQ_PS=0;
        //采样窗口大小,SOC脉冲宽度为1个ADCLK
        AdcRegs.ADCTRL1.bit.CPS=0;
        //核时钟预定标器,等于0,未将时钟进行2分频
        AdcRegs.ADCTRL1.bit.CONT_RUN=0;
        //运行于启动/停止模式
        AdcRegs.ADCTRL1.bit.SEQ_CASC=1;
        //级联方式
        AdcRegs.ADCTRL3.bit.ADCBGRFDN=3;
        for(i=0;i<10000;i++)        NOP;
        AdcRegs.ADCTRL3.bit.ADCPWDN=1;
        for(i=0;i<5000;i++)        NOP;
        AdcRegs.ADCTRL3.bit.ADCCLKPS=15;
        //ADCLK=HSPCLK/30
        AdcRegs.ADCTRL3.bit.SMODE_SEL=0;
        //采用顺序采样模式
        AdcRegs.MAX_CONV.bit.MAX_CONV=15;
        //总共采样16路
        AdcRegs.CHSELSEQ1.bit.CONV00=0;
        AdcRegs.CHSELSEQ1.bit.CONV01=1;
        AdcRegs.CHSELSEQ1.bit.CONV02=2;
        AdcRegs.CHSELSEQ1.bit.CONV03=3;
        AdcRegs.CHSELSEQ2.bit.CONV04=4;
        AdcRegs.CHSELSEQ2.bit.CONV05=5;
        AdcRegs.CHSELSEQ2.bit.CONV06=6;
        AdcRegs.CHSELSEQ2.bit.CONV07=7;
        AdcRegs.CHSELSEQ3.bit.CONV08=8;
        AdcRegs.CHSELSEQ3.bit.CONV09=9;
        AdcRegs.CHSELSEQ3.bit.CONV10=10;
        AdcRegs.CHSELSEQ3.bit.CONV11=11;
        AdcRegs.CHSELSEQ4.bit.CONV12=12;
        AdcRegs.CHSELSEQ4.bit.CONV13=13;
        AdcRegs.CHSELSEQ4.bit.CONV14=14;
        AdcRegs.CHSELSEQ4.bit.CONV15=15;
        AdcRegs.ADC_ST_FLAG.bit.INT_SEQ1_CLR=1;
        //清除SEQ1中的中断标志位INT_SEQ1
        AdcRegs.ADC_ST_FLAG.bit.INT_SEQ2_CLR=1;
        //清除SEQ2中的中断标志位INT_SEQ2
        AdcRegs.ADCTRL2.bit.EVB_SOC_SEQ=0;
        AdcRegs.ADCTRL2.bit.RST_SEQ1=0;
        AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1=1;
        AdcRegs.ADCTRL2.bit.INT_MOD_SEQ1=0;
        AdcRegs.ADCTRL2.bit.EVA_SOC_SEQ1=0;
        AdcRegs.ADCTRL2.bit.EXT_SOC_SEQ1=0;
        AdcRegs.ADCTRL2.bit.RST_SEQ2=0;
        AdcRegs.ADCTRL2.bit.SOC_SEQ2=0;
        AdcRegs.ADCTRL2.bit.INT_ENA_SEQ2=0;
        AdcRegs.ADCTRL2.bit.INT_MOD_SEQ2=0;
        AdcRegs.ADCTRL2.bit.EVB_SOC_SEQ2=0;
        AdcRegs.ADCTRL2.bit.SOC_SEQ1=1;
ADCINA0-7,ADCINB0-7,ADCLO 都接DGND,存储ad转换的寄存器值不为0,adcin引脚接0-3V的电压,寄存器的值也不变,是什么原因
houcs| | 2020-4-25 19:42 | 只看该作者
先运行下例程,确定是不是你的DSP的AD模块坏了
pangb| | 2020-4-25 19:44 | 只看该作者
ADCLO是接模拟地的
zyf部长| | 2020-4-25 19:45 | 只看该作者
看下你的AD结果存在哪里了
wangpe| | 2020-4-25 19:47 | 只看该作者
取结果是否正确,每个ADC要放到对应通道里
zhanglli| | 2020-4-25 19:49 | 只看该作者
我也遇到了,B0的采样结果一直就是这样!
happy_10| | 2020-4-25 19:52 | 只看该作者
adc的设计还是比较不错的资料
zhuhuis| | 2020-4-25 19:54 | 只看该作者
数据是多大?
zwll| | 2020-4-25 19:58 | 只看该作者
就是没有正常采样。
pengf| | 2020-4-25 20:00 | 只看该作者
使用的是定时器触发
houcs| | 2020-4-25 20:03 | 只看该作者
如果配置正确,ADC也会变化的。
ousj| | 2020-4-25 20:04 | 只看该作者
怎么不使用外部的ADC呢?
kangzj| | 2020-4-25 20:06 | 只看该作者
是不同的IO采样吗?
yufe| | 2020-4-25 20:08 | 只看该作者
ADC采样没有触发
zhuww| | 2020-4-25 20:10 | 只看该作者
顺序采样触发才可以。
chenho| | 2020-4-25 20:12 | 只看该作者
应该是ADC有问题。
stly| | 2020-4-25 20:13 | 只看该作者
外部的ADC芯片比较高端一些。
