[DemoCode下载] M261的Blink操作
859|10
 楼主| huangcunxiake 发表于 2020-4-27 23:31 | 显示全部楼层 |阅读模式
  1. /******************************************************************************
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
  4. * [url=home.php?mod=space&uid=247401]@brief[/url]    A simple demo for NuTiny-M261 board to show message from UART5 to ICE VCOM.
  5. *
  6. *
  7. * [url=home.php?mod=space&uid=17282]@CopyRight[/url] (C) 2019 Nuvoton Technology Corp. All rights reserved.
  8. *****************************************************************************/
  9. #include <stdio.h>
  10. #include "NuMicro.h"
  11. #include "clk.h"
  12. #include "uart.h"
  13. #include "gpio.h"
  14. #include "sys.h"
  15. #define LED_INIT()  {PB->MODE = (PB->MODE &(~(0xf << 10*2))) | (0x5 << 10 * 2);}
  16. #define LED_RED     PB10
  17. void SYS_Init(void)
  18. {
  19.     /* Enable PLL */
  20.     CLK->PLLCTL = CLK_PLLCTL_128MHz_HIRC;
  21.     /* Waiting for PLL stable */
  22.     while((CLK->STATUS & CLK_STATUS_PLLSTB_Msk) == 0);
  23.     /* Set HCLK divider to 2 */
  24.     CLK->CLKDIV0 = (CLK->CLKDIV0 & (~CLK_CLKDIV0_HCLKDIV_Msk)) | 1;
  25.     /* Switch HCLK clock source to PLL */
  26.     CLK->CLKSEL0 = (CLK->CLKSEL0 & (~CLK_CLKSEL0_HCLKSEL_Msk)) | CLK_CLKSEL0_HCLKSEL_PLL;
  27.     /* Select IP clock source */
  28.     CLK->CLKSEL1 = CLK_CLKSEL1_UART0SEL_HIRC;
  29.     /* Enable IP clock */
  30.     CLK->APBCLK0 |= CLK_APBCLK0_UART0CKEN_Msk;
  31.     /* Update System Core Clock */
  32.     /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
  33.     //SystemCoreClockUpdate();
  34.     PllClock        = 128000000;            // PLL
  35.     SystemCoreClock = 128000000 / 2;        // HCLK
  36.     CyclesPerUs     = 64000000 / 1000000;   // For SYS_SysTickDelay()
  37.     /*---------------------------------------------------------------------------------------------------------*/
  38.     /* Init I/O Multi-function        */
  39.     /*---------------------------------------------------------------------------------------------------------*/
  40.     /* Set multi-function pins for UART0 RXD and TXD */
  41.     SYS->GPB_MFPH = (SYS->GPB_MFPH & (~(UART0_RXD_PB12_Msk | UART0_TXD_PB13_Msk))) | UART0_RXD_PB12 | UART0_TXD_PB13;
  42. }
  43. void UART0_Init()
  44. {
  45.     /*---------------------------------------------------------------------------------------------------------*/
  46.     /* Init UART        */
  47.     /*---------------------------------------------------------------------------------------------------------*/
  48.     UART0->LINE = UART_PARITY_NONE | UART_STOP_BIT_1 | UART_WORD_LEN_8;
  49.     UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HIRC, 115200);
  50. }
  51. int main()
  52. {
  53.     SYS_UnlockReg();
  54.     SYS_Init();
  55.     UART0_Init();
  56.     printf("\n");
  57.     printf("+------------------------------------------------------------------+\n");
  58.     printf("|              Simple Blinky Demo                                  |\n");
  59.     printf("+------------------------------------------------------------------+\n");
  60.     /* Init GPIO for LED toggle */
  61.     LED_INIT();
  62.     LED_RED = 0;
  63.     while(1)
  64.     {
  65.         LED_RED ^= 1;
  66.         CLK_SysTickLongDelay(200000);
  67.         LED_RED ^= 1;
  68.         CLK_SysTickLongDelay(200000);
  69.     }
  70. }
  71. /*** (C) COPYRIGHT 2019 Nuvoton Technology Corp. ***/
 楼主| huangcunxiake 发表于 2020-4-27 23:32 | 显示全部楼层
http://www.nuvoton.com.cn/export/resource-files/M261_Series_BSP_CMSIS_V3.00.002.zip
这个BSP里面例子超级丰富。
643757107 发表于 2020-4-27 23:34 | 显示全部楼层
新唐的库函数现在做的非常好了
598330983 发表于 2020-4-27 23:52 | 显示全部楼层
串口是不是要设置重定向。
734774645 发表于 2020-4-27 23:53 | 显示全部楼层
另外通过官方例程学习编程,也是非常棒的
yiy 发表于 2020-4-27 23:57 | 显示全部楼层
延时函数很好用。
xixi2017 发表于 2020-4-27 23:57 | 显示全部楼层
官方的库函数非常好。
xuanhuanzi 发表于 2020-4-27 23:57 | 显示全部楼层
入门必备的例子,都是从这个学的。
zhuomuniao110 发表于 2020-4-27 23:58 | 显示全部楼层
如果有详细讲解的就好了,有的函数看不懂啥意思,有的宏看着意思差不多。
小明的同学 发表于 2020-4-30 19:45 | 显示全部楼层
看来看去,还是新唐的库函数做的好用。所有系列的库函数都很统一。
小灵通2018 发表于 2020-4-30 20:05 | 显示全部楼层
这个例子非常好理解,比其他厂家的好多了。
