MAX31855K 源代码
628|0
 楼主| maximQ820270087 发表于 2020-5-5 12:21 | 显示全部楼层 |阅读模式
* @file Max31855.c
* @brief    Max31855����ģ��
* @version      1.0
* @date 2014�� 5�� 9 ��
* @author   ����ƽ
**--------------��ǰ�汾�޶�------------------------------------------------------------------------------
** �ա���:
** �衡��:
/** @addtogroup Max31855
#include "../include/Max31855.h"
Max31855_DATA ChipOut;
* @fun readdata
* @brief   ��ȡMAX31855��ѹֵ
* @param   None
* @return  �������
static uint8_t readdata(uint32_t *pData)
    uint8_t i;
    uint32_t tmp;
    static uint16_t timesticke = 0;
    if(timesticke < 2000)
        timesticke++;
        return 0;
    else
        tmp = 0;
        MAX31855_CLK = LVAR;
        MAX31855_CS = LVAR;
        for(i = 0; i < 32; i++)
            asm("nop;");
            MAX31855_CLK = HVAR;
            tmp = tmp<<1;
            if(MAX31855_DATA == HVAR)
                tmp |= 1;
            else
                tmp &= ~1;
            asm("nop;");
            asm("nop;");
            asm("nop;");
        MAX31855_CS = HVAR;
        *pData = tmp;
        timesticke = 0;
        return 1;
* @fun Max31855_GetTemperatureValue
* @brief   ��ȡ�ȵ�ż�¶�ֵ
* @param   None
* @return  �ȵ�ż�¶�ֵ
int32_t Max31855_GetTemperatureValue(void)
    int32_t retHTe;
    uint32_t temp;
    if(readdata(&temp))
        ChipOut.all = temp;
    retHTe = ChipOut.bit.HTemperature;
    return retHTe;
* @fun GetMax31855Fault
* @brief   ��ȡ�ȵ�ż�������
* @param   None
* @return  0:�޹��� 1:��· 2: �ڵض�· 3:��VCC��·
uint8_t GetMax31855Fault(void)
    if(ChipOut.bit.Fault**)
        if(ChipOut.bit.OC)
            return 1;
        if(ChipOut.bit.SCG)
            return 2;
        if(ChipOut.bit.SCV)
            return 3;
    return 0;
