应广单片机第四季03数组
544|0
 楼主| 34af9uc 发表于 2020-5-10 23:04 | 显示全部楼层 |阅读模式
https://www.bilibili.com/video/BV11f4y1m7TK/
<iframe src="//player.bilibili.com/player.html?aid=285601335&bvid=BV11f4y1m7TK&cid=189563419&page=1" scrolling="no" border="0" frameborder="no" framespacing="0" allowfullscreen="true"> </iframe>
#include        "extern.h"
led_zuo                bit                pa.6;
led_you                bit                pa.5;
led_a                bit                pa.0;
led_b                bit                pa.7;
led_c                bit                pa.4;
led_d                bit                pa.3;
led_e                bit                pb.3;
led_f                bit                pb.1;
led_g                bit                pb.0;
void        FPPA0 (void)
.ADJUST_IC        SYSCLK=IHRC/4                //        SYSCLK=IHRC/4
byte led_a1;
byte b1;
byte        led_zu[11];        //数码管编码
led_zu[0]        =0xfc;        //0
led_zu[1]        =0x60;        //1
led_zu[2]        =0xda;        //2
led_zu[3]        =0xf2;        //3
led_zu[4]        =0x66;        //4
led_zu[5]        =0xb6;        //5
led_zu[6]        =0xbe;        //6
led_zu[7]        =0xe0;        //7
led_zu[8]        =0xfe;        //8
led_zu[9]        =0xf6;        //9
$                led_zuo                out,high;                //设置为输出,输出为1
$                led_you                out,high;
$                led_a                out,high;
$                led_b                out,high;
$                led_c                out,high;
$                led_d                out,high;
$                led_e                out,high;
$                led_f                out,high;
$                led_g                out,high;
b1=0;
if(b1==0)        led_a1         =led_zu[0];
if(b1==1)        led_a1         =led_zu[1];
if(b1==2)        led_a1         =led_zu[2];
if(b1==3)        led_a1         =led_zu[3];
if(b1==4)        led_a1         =led_zu[4];
if(b1==5)        led_a1         =led_zu[5];
if(b1==6)        led_a1         =led_zu[6];
if(b1==7)        led_a1         =led_zu[7];*/
while (1)
if(b1==8)        led_a1         =led_zu[8];
if(b1==9)        led_a1         =led_zu[9];
if(led_a1.7)        led_a=0;        else led_a=1;
if(led_a1.6)        led_b=0;        else led_b=1;
if(led_a1.5)        led_c=0;        else led_c=1;
if(led_a1.4)        led_d=0;        else led_d=1;
if(led_a1.3)        led_e=0;        else led_e=1;
if(led_a1.2)        led_f=0;        else led_f=1;
if(led_a1.1)        led_g=0;        else led_g=1;
b1++;
if(b1>9)        b1=0;
.delay 2000000;
