SDIO小问题
240|0
 楼主| 哈金 发表于 2019-11-13 14:14 | 显示全部楼层 |阅读模式
IO, sd, ni, ST, ck
SDIO_InitStructure.SDIO_ClockDiv = SDIO_TRANSFER_CLK_DIV;
SDIO_InitStructure.SDIO_ClockEdge = SDIO_ClockEdge_Rising;
SDIO_InitStructure.SDIO_ClockBypass = SDIO_ClockBypass_Disable;
SDIO_InitStructure.SDIO_ClockPowerSave = SDIO_ClockPowerSave_Disable;
SDIO_InitStructure.SDIO_BusWide = SDIO_BusWide_1b;
SDIO_InitStructure.SDIO_HardwareFlowControl = SDIO_HardwareFlowControl_Disable;
SDIO_Init(&SDIO_InitStructure);
这堆定义在sd初始化 SD_Init();函数中定义了,,然后再SD_Init();函数调用的SD_PowerO();函数中又定义了一次
我把SD_Init();中这一部分注释了,,程序运行正常;
这有什么隐含的意义所在吗
