[STM32F1] PWM驱动四轴电机失败
559|12
 楼主| dingy 发表于 2020-5-14 23:35 | 显示全部楼层 |阅读模式
void MotorInit(void)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        TIM_OCInitTypeDef TIM_OCInitStructure;
        uint16_t PrescalerValue = 0;                                                //用于控制电机PWM频率
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);                       //打开GPIOA的时钟
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,  ENABLE);                       //打开定时器2时钟
        GPIO_InitStructure.GPIO_Mode =  GPIO_Mode_AF_PP;                            //利用TIM2,所以复用输出
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;  //PA0123
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                            //搞不懂为什么用2Mhz
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        //复位定时器
        TIM_DeInit(TIM2);
        /*这里配置计时器*/
    PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;               //一秒钟计数多少次,2次
        TIM_TimeBaseStructure.TIM_Period = 999;        //单次计数个数
        TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;                       //设置预分频系数
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;                 //向上计数
        TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
        /*配置TIM2为PWM输出模式*/
        TIM_OCStructInit(&TIM_OCInitStructure);
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;                           //设置为PWM1模式
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;               //开启OC*输出到对应引脚
        TIM_OCInitStructure.TIM_Pulse = 0;        //CCR1设置为0
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;                       //高电平有效
    TIM_OC1Init(TIM2,&TIM_OCInitStructure);                                         //初始化指定外设
    TIM_OC2Init(TIM2,&TIM_OCInitStructure);
    TIM_OC3Init(TIM2,&TIM_OCInitStructure);
    TIM_OC4Init(TIM2,&TIM_OCInitStructure);
    TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);                                         //使能预装载器
    TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable);
    TIM_OC3PreloadConfig(TIM2, TIM_OCPreload_Enable);
    TIM_OC4PreloadConfig(TIM2, TIM_OCPreload_Enable);
        TIM_ARRPreloadConfig(TIM2,ENABLE);//使能TIM3在 ARR 上的预装载寄存器。
        //启动定时器
    TIM_Cmd(TIM2,ENABLE);
    printf("Motor init success...\r\n");
初始化完后,是不是修改CCRx中的值就能运行?还是有什么其他的设置。
void MotorPwmFlash(int16_t MOTO1_PWM, int16_t MOTO2_PWM, int16_t MOTO3_PWM, int16_t MOTO4_PWM)
        if(MOTO1_PWM>=Moto_PwmMax)        MOTO1_PWM = Moto_PwmMax;
        if(MOTO2_PWM>=Moto_PwmMax)        MOTO2_PWM = Moto_PwmMax;
        if(MOTO3_PWM>=Moto_PwmMax)        MOTO3_PWM = Moto_PwmMax;
        if(MOTO4_PWM>=Moto_PwmMax)        MOTO4_PWM = Moto_PwmMax;
        if(MOTO1_PWM<=0)        MOTO1_PWM = 0;
        if(MOTO2_PWM<=0)        MOTO2_PWM = 0;
        if(MOTO3_PWM<=0)        MOTO3_PWM = 0;
        if(MOTO4_PWM<=0)        MOTO4_PWM = 0;        //限定输入不能小于0,大于999
        TIM2->CCR1 = MOTO1_PWM;
    TIM2->CCR2 = MOTO2_PWM;
    TIM2->CCR3 = MOTO3_PWM;
    TIM2->CCR4 = MOTO4_PWM;                       //对定时器寄存器进行赋值
        printf("TIM->CCR1 %d ", TIM2->CCR1);
        printf("TIM->CCR1 %d ", TIM2->CCR2);
        printf("TIM->CCR1 %d ", TIM2->CCR3);
        printf("TIM->CCR1 %d \n", TIM2->CCR4);
songqian17 发表于 2020-5-14 23:38 | 显示全部楼层
你有什么打算呢?或者你想知道什么?
 楼主| dingy 发表于 2020-5-14 23:40 | 显示全部楼层
我在main函数中调用,并没有成功转起来。请问会是什么没弄好呢?谢谢
llljh 发表于 2020-5-14 23:46 | 显示全部楼层
不是硬件mos电路的问题吗
liuzaiy 发表于 2020-5-14 23:49 | 显示全部楼层
示波器测量的波形都对吗?
 楼主| dingy 发表于 2020-5-14 23:52 | 显示全部楼层
是没上电的问题。。。PWM都是对的
yufe 发表于 2020-5-14 23:56 | 显示全部楼层
电压驱动不足。
stly 发表于 2020-5-19 21:58 | 显示全部楼层
你这是做什么应用?
llljh 发表于 2020-5-19 22:03 | 显示全部楼层
我都是用IO先模拟一下,然后PWM配置再用PWM,示波器测波形。
houcs 发表于 2020-5-19 22:07 | 显示全部楼层
解决了?没有给电机供电?
morrisk 发表于 2020-5-19 22:09 | 显示全部楼层
示波器看下波形
guoyt 发表于 2020-5-19 22:12 | 显示全部楼层
这个程序怎么跟32一样啊
 楼主| dingy 发表于 2020-5-19 22:18 | 显示全部楼层
好的,我明天去单位试一下,多谢各位大侠了哈
