AT45DB161D_Flash 读取不了ID号??
579|0
 楼主| 小小的人呀 发表于 2019-11-17 12:00 | 显示全部楼层 |阅读模式
有人用过AT45DB161D的Flash片子没?   我读取的ID号是全FF  正确的应该是0x1F260000  求助啊   纠结好久了~~~
FlashID = SPI_FLASH_ReadID();
u32 SPI_FLASH_ReadID(void)
  u32 Temp = 0, Temp0 = 0, Temp1 = 0, Temp2 = 0, Temp3 = 0;
  /* Select the FLASH: Chip Select low */
  SPI_FLASH_CS_LOW();
  /* Send "RDID " instruction */
  SPI_FLASH_SendByte(0x9F);                //Manufacturer and Device Read   Datasheet P44
  /* Read a byte from the FLASH */
  Temp0 = SPI_FLASH_SendByte(Dummy_Byte);
        //printf("Temp0 =0x%X\n",Temp0);
  Temp1 = SPI_FLASH_SendByte(Dummy_Byte);
//        printf("Temp1 =0x%X\n",Temp1);
  Temp2 = SPI_FLASH_SendByte(Dummy_Byte);
//        printf("Temp2 =0x%X\n",Temp2);
  Temp3 = SPI_FLASH_SendByte(Dummy_Byte);
// printf("Temp3 =0x%X\n",Temp3);
  /* Deselect the FLASH: Chip Select high */
  SPI_FLASH_CS_HIGH();
  Temp = (Temp0 << 24) | (Temp1 << 16) | (Temp2<<8) | Temp3;
  return Temp;
