μCOS-III的信号量创建失败问题
544|0
 楼主| 电子学长 发表于 2019-11-17 13:56 | 显示全部楼层 |阅读模式
各位大神,我今天刚学到信号量,写了一个小程序,建立两个任务,分别使两个小灯闪烁。我想创建一个信号量,我看到书上解释说OSSemCreate()函数中给OS_SEM_CTR这个参数赋的值就是信号量的初始值,我在程序中给它赋值为2,可是我用串口打印出sem_led1->Ctr的值是0呢?  是我这个函数的写法不对还是怎么回事?  在线等,急急急!!!!
#include "app.h"
#include "bsp.h"
OS_TCB LED1_TCB;
static        CPU_STK LED1_Stk[128];
OS_TCB LED2_TCB;
static        CPU_STK LED2_Stk[128];
OS_SEM *sem_led1;
int main(void)
        OS_ERR err;
        BSP_Init();
        OSInit(&err);
        OSSemCreate ((OS_SEM        *)sem_led1,
                                  (CPU_CHAR    *)"led1",
                                  (OS_SEM_CTR )2,
                                  (OS_ERR        *)&err);
        OSTaskCreate ((OS_TCB        *)&LED1_TCB,
                (CPU_CHAR      *)"LED1",
                (OS_TASK_PTR    )Task_LED1,
                (void          *)0,
                (OS_PRIO        )2,
                (CPU_STK       *)&LED1_Stk[0],
                (CPU_STK_SIZE   )12,
                (CPU_STK_SIZE   )128,
                (OS_MSG_QTY     )0,
                (OS_TICK        )0,
                (void          *)0,
                (OS_OPT         )OS_OPT_TASK_STK_CHK|OS_OPT_TASK_STK_CLR,
                (OS_ERR        *)&err);
OSTaskCreate ((OS_TCB        *)&LED2_TCB,
                (CPU_CHAR      *)"LED2",
                (OS_TASK_PTR    )Task_LED2,
                (void          *)0,
                (OS_PRIO        )3,
                (CPU_STK       *)&LED2_Stk[0],
                (CPU_STK_SIZE   )12,
                (CPU_STK_SIZE   )128,
                (OS_MSG_QTY     )0,
                (OS_TICK        )0,
                (void          *)0,
                (OS_ERR        *)&err);
        printf("\r\n%d",sem_led1->Ctr);
        OSStart(&err);
