TIM3生成4路PWM 有两路无输出
466|0
 楼主| 追光少年 发表于 2019-11-21 11:10 | 显示全部楼层 |阅读模式
TI, PWM, pi, IO, ni
/* 初始化上层控制电机两个IO口 B0 B1 */
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC, ENABLE); //使能时钟
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                    // 复用推挽输出
        /* 上层电机 B0  B1 */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
        /* 下层电机 C6  C7 */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7;
        GPIO_Init(GPIOC, &GPIO_InitStructure);
        /* 初始化TIM模块 */
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);                                         //使能TIM3时钟
        TIM_TimeBaseStructure.TIM_Prescaler=0;//预分频为0
        TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;//向上计数
        TIM_TimeBaseStructure.TIM_Period=10285;
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;    //时钟分频系数为0
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);   //TIM3初始化
        TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM1;//模式1
        TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;//正向通道输出使能
        TIM_OCInitStructure.TIM_Pulse = 2400;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;     //正向通道输出极性
        TIM_OC1Init(TIM3, &TIM_OCInitStructure);//使能通道1
        TIM_OC2Init(TIM3, &TIM_OCInitStructure);//使能通道2
        TIM_OC3Init(TIM3, &TIM_OCInitStructure);//使能通道3
        TIM_OC4Init(TIM3, &TIM_OCInitStructure);//使能通道4
        TIM_Cmd(TIM3, ENABLE);
