液晶显示BMP图片的路径如何设置?
755|0
 楼主| 肉坨坨 发表于 2019-11-28 12:28 | 显示全部楼层 |阅读模式
使用STM32的例程,可以显示图片,把图片换成其它BMP图片,修改Lcd_show_bmp(0, 0,"/tupian.bmp");,并把图片放到SD卡,液晶不能显示图片,那么图片的路径是如何设置的?
void Lcd_show_bmp(unsigned short int x, unsigned short int y,unsigned char *pic_name)
        int i, j, k;
        int width, height, l_width;
        BYTE red,green,blue;
        BITMAPFILEHEADER bitHead;
        BITMAPINFOHEADER bitInfoHead;
        WORD fileType;
        unsigned int read_num;
        unsigned char tmp_name[20];
        sprintf((char*)tmp_name,"0:%s",pic_name);
        f_mount(0, &bmpfs[0]);
        BMP_DEBUG_PRINTF("file mount ok \r\n");
        bmpres = f_open( &bmpfsrc , (char *)tmp_name, FA_OPEN_EXISTING | FA_READ);
        if(bmpres == FR_OK)
                BMP_DEBUG_PRINTF("Open file success\r\n");
                f_read(&bmpfsrc,&fileType,sizeof(WORD),&read_num);
                if(fileType != 0x4d42)
                        BMP_DEBUG_PRINTF("file is not .bmp file!\r\n");
                        return;
                else
                        BMP_DEBUG_PRINTF("Ok this is .bmp file\r\n");
                f_read(&bmpfsrc,&bitHead,sizeof(tagBITMAPFILEHEADER),&read_num);
                showBmpHead(&bitHead);
                f_read(&bmpfsrc,&bitInfoHead,sizeof(BITMAPINFOHEADER),&read_num);
                showBmpInforHead(&bitInfoHead);
        else
                BMP_DEBUG_PRINTF("file open fail!\r\n");
                return;
        width = bitInfoHead.biWidth;
        height = bitInfoHead.biHeight;
        l_width = WIDTHBYTES(width* bitInfoHead.biBitCount);
        if(l_width > 960)
                BMP_DEBUG_PRINTF("\n SORRY, PIC IS TOO BIG (<=320)\n");
                return;
        Lcd_GramScan( 3 );
        LCD_OpenWindow(x, y, width, height);
        /* 判断是否是24bit真彩色图 */
        if(bitInfoHead.biBitCount >= 24)
                for(i=0;i< height; i++)
                        /* 读取一行bmp的数据到数组pColorData里面 */
                        #if 0
                                for(j=0; j< l_width; j++)
                                        f_read(&bmpfsrc,pColorData+j,1,&read_num);
                        #elif 1
                                f_read(&bmpfsrc,pColorData,l_width/2,&read_num);
                                f_read(&bmpfsrc,pColorData+l_width/2,l_width/2,&read_num);
                        #else
                                f_read(&bmpfsrc,pColorData,l_width,&read_num);
                        #endif
                        for(j=0; j<width; j++)        //一行有效信息
                                k = j*3;        //一行中第K个像素的起点
                                red = pColorData[k+2];
                                green = pColorData[k+1];
                                blue =         pColorData[k];
                                LCD_WR_Data(RGB24TORGB16(red,green,blue)); //写入LCD-GRAM
        else
                BMP_DEBUG_PRINTF("SORRY, THIS PIC IS NOT A 24BITS REAL COLOR");
                return ;
        f_close(&bmpfsrc);
