[STM32L0]
停止模式
654|7
pengf|  楼主 | 2020-5-27 22:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
pi, IO, GPIO, gp, ST
进入停止模式之前调用了:
SystemPower_Config()函数
static void SystemPower_Config(void)
  /* Enable Ultra low power mode */
  HAL_PWREx_EnableUltraLowPower();
  /* Enable the fast wake up from Ultra low power mode */
  HAL_PWREx_EnableFastWakeUp();
  /* Select HSI as system clock source after Wake Up from Stop mode */
  __HAL_RCC_WAKEUPSTOP_CLK_CONFIG(RCC_STOP_WAKEUPCLOCK_HSI);
  /* Enable GPIOs clock */
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  /* Configure all GPIO port pins in Analog Input mode (floating input trigger OFF) */
  GPIO_InitStructure.Pin = GPIO_PIN_All;
  GPIO_InitStructure.Mode = GPIO_MODE_ANALOG;
  GPIO_InitStructure.Pull = GPIO_NOPULL;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStructure);
  HAL_GPIO_Init(GPIOB, &GPIO_InitStructure);
  HAL_GPIO_Init(GPIOC, &GPIO_InitStructure);
  HAL_GPIO_Init(GPIOD, &GPIO_InitStructure);
  HAL_GPIO_Init(GPIOH, &GPIO_InitStructure);
  /* Disable GPIOs clock */
  __HAL_RCC_GPIOA_CLK_DISABLE();
  __HAL_RCC_GPIOB_CLK_DISABLE();
  __HAL_RCC_GPIOC_CLK_DISABLE();
  __HAL_RCC_GPIOD_CLK_DISABLE();
  __HAL_RCC_GPIOH_CLK_DISABLE();
然后进入: HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON, PWR_STOPENTRY_WFI);
SystemClockConfig_STOP();
唤醒正常,但是重新初始化串口(串口里面初始化了GPIO和CLK),却无法打印,这是为什么?
gongche| | 2020-5-27 22:16 | 只看该作者
你可以参考一下。官方的低功耗的串口的使用方法
huwr| | 2020-5-27 22:20 | 只看该作者
都搞死了  怎么能用!
huanghuac| | 2020-5-27 22:23 | 只看该作者
时钟全关闭?
pengf|  楼主 | 2020-5-27 22:27 | 只看该作者
嗯,我再好好缕一缕吧,有了好消息及时通知大家
keaibukelian| | 2020-6-8 14:38 | 只看该作者
是不是还需要重新配置一下io口啊
labasi| | 2020-6-8 14:38 | 只看该作者
io口的时钟你都禁止使能了
paotangsan| | 2020-6-8 14:39 | 只看该作者
这可是低级错误
