窗口法求FIR滤波器系数
2035|9
 楼主| 叶春勇 发表于 2020-5-28 10:54 | 显示全部楼层 |阅读模式
理想低通、高通、带通、高通的线性相位数字滤波器的表达式
程佩青《数字信号处理教程第四版》P476-P478
转换成计算机函数:
 楼主| 叶春勇 发表于 2020-5-28 10:55 | 显示全部楼层
python求fir滤波器,矩形窗
  1. import math
  2. def sinc(x):
  3.     if x==0.0:
  4.         return 1.0
  5.     else:
  6.         return math.sin(math.pi*x)/math.pi/x
  7. def impulse(x):
  8.     if x==0.0:
  9.         return 1.0
  10.     else :
  11.         return 0
  12. N=9
  13. #线性相位条件
  14. k=(N-1)/2
  15. #测试低通高通
  16. fc=0.1
  17. #测试带通带阻
  18. f1=0.1
  19. f2=0.2
  20. #低通
  21. for i in range(0,N,1):
  22.     print(2*fc*sinc(2*fc*(i-k)))
  23. print('------------------------')
  24. #高通
  25. for i in range(0,N,1):
  26.     print(impulse(i-k)-2*fc*sinc(2*fc*(i-k)))
  27. print('------------------------')
  28. #带通
  29. for i in range(0,N,1):
  30.     print(2*f2*sinc(2*f2*(i-k))-2*f1*sinc(2*f1*(i-k)))
  31. print('------------------------')
  32. #带阻
  33. for i in range(0,N,1):
  34.     print(sinc(i-k)-2*f2*sinc(2*f2*(i-k))+2*f1*sinc(2*f1*(i-k)))
  35. print('------------------------')
 楼主| 叶春勇 发表于 2020-5-28 10:57 | 显示全部楼层
求得的系数
  1. -------低通---------------
  2. 0.046774464189431965
  3. 0.10091023048542092
  4. 0.1513653457281314
  5. 0.1870978567577278
  6. 0.2
  7. 0.1870978567577278
  8. 0.1513653457281314
  9. 0.10091023048542092
  10. 0.046774464189431965
  11. -------高通---------------
  12. -0.046774464189431965
  13. -0.10091023048542092
  14. -0.1513653457281314
  15. -0.1870978567577278
  16. 0.8
  17. -0.1870978567577278
  18. -0.1513653457281314
  19. -0.10091023048542092
  20. -0.046774464189431965
  21. -------带通---------------
  22. -0.12245713705349767
  23. -0.16327618273799688
  24. -0.05781641734926747
  25. 0.115632834698535
  26. 0.2
  27. 0.115632834698535
  28. -0.05781641734926747
  29. -0.16327618273799688
  30. -0.12245713705349767
  31. -------带阻---------------
  32. 0.12245713705349762
  33. 0.1632761827379969
  34. 0.05781641734926743
  35. -0.11563283469853494
  36. 0.8
  37. -0.11563283469853494
  38. 0.05781641734926743
  39. 0.1632761827379969
  40. 0.12245713705349762
 楼主| 叶春勇 发表于 2020-5-28 11:02 | 显示全部楼层
用matlab算出来的系数:
>> LP
LP =
  Columns 1 through 6
   0.046774464189432   0.100910230485421   0.151365345728131   0.187097856757728   0.200000000000000   0.187097856757728
  Columns 7 through 9
   0.151365345728131   0.100910230485421   0.046774464189432
>> HP
HP =
  Columns 1 through 6
  -0.046774464189432  -0.100910230485421  -0.151365345728131  -0.187097856757728   0.800000000000000  -0.187097856757728
  Columns 7 through 9
  -0.151365345728131  -0.100910230485421  -0.046774464189432
>> BP
BP =
  Columns 1 through 6
  -0.122457137053498  -0.163276182737997  -0.057816417349267   0.115632834698535   0.200000000000000   0.115632834698535
  Columns 7 through 9
  -0.057816417349267  -0.163276182737997  -0.122457137053498
>> BS
BS =
  Columns 1 through 6
   0.122457137053498   0.163276182737997   0.057816417349267  -0.115632834698535   0.800000000000000  -0.115632834698535
  Columns 7 through 9
   0.057816417349267   0.163276182737997   0.122457137053498[code][/code]
 楼主| 叶春勇 发表于 2020-5-28 11:03 | 显示全部楼层
MATLAB滤波器设计工具-fdatool
低通
评分
参与人数 1威望 +10 收起 理由
congfenglong + 10 很给力!
查看全部评分
高通:
 楼主| 叶春勇 发表于 2020-5-28 11:04 | 显示全部楼层
带通:
带阻:
 楼主| 叶春勇 发表于 2020-5-28 11:14 | 显示全部楼层
总结:
在学习过程中,原来以为matlab的sinc函数就是sin(x)/x,实际上是归一化的sin(pi*x)/(pi*x)。发现系数对不上。
窗口法设计规则滤波器非常好用。
如果设计,多阻带,多带通,或者带通和高通混合的滤波,需要是用频率采样法设计一个超现实的滤波器。
作为fir滤波器系数的手工计算,目前目标,窗口法和频率采样法。至于其他方法就不在投入精力。
该用户名已注册 发表于 2020-5-29 15:17 | 显示全部楼层
总结不错  谢谢分享
