[MCU] 用2块板子进行CAN通信
924|12
 楼主| pengf 发表于 2020-5-29 23:23 | 显示全部楼层 |阅读模式
一块发送一块接受,可以做到,认为CAN模块是好的。
然后我开始与CAN设备通信,1个邮箱发送一个邮箱接收,ID与协议设置的一致,波特率当然也一致,不然发送不了。
hanwe 发表于 2020-5-29 23:26 | 显示全部楼层
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
 楼主| pengf 发表于 2020-5-29 23:27 | 显示全部楼层
void main()
unsigned int kk, t;
/* Create a shadow register structure for the CAN control registers. This is
needed, since, only 32-bit access is allowed to these registers. 16-bit access
to these registers could potentially corrupt the register contents. This is
especially true while writing to a bit (or group of bits) among bits 16 - 31 */
//   struct ECAN_REGS ECanaShadow;
   struct ECAN_REGS ECanbShadow;
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP2833x_SysCtrl.c file.
   InitSysCtrl();
// Step 2. Initalize GPIO:
// This example function is found in the DSP2833x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio();  // Skipped for this example
   // Just initalize eCAN pins for this example
   // This function is in DSP2833x_ECan.c
//  InitECanGpio();
   InitECanbGpio();
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
   DINT;
// Initialize the PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the DSP2833x_PieCtrl.c file.
   InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
   IER = 0x0000;
   IFR = 0x0000;
   InitPieVectTable();
  // InitECan();
  InitECanb();
  ECanbMboxes.MBOX24.MSGID.all = 0x90200000; // Extended Identifier
  ECanbShadow.CANMD.all = ECanbRegs.CANMD.all;
   ECanbShadow.CANMD.bit.MD24 = 1;    ///  1: 接收邮箱  0:发送邮箱
   ECanbRegs.CANMD.all = ECanbShadow.CANMD.all;
   ECanbShadow.CANME.all = ECanbRegs.CANME.all;
  ECanbShadow.CANME.bit.ME24 = 1;     ///  1:使能    0:  不使能
   ECanbRegs.CANME.all = ECanbShadow.CANME.all;
   ECanbMboxes.MBOX24.MSGCTRL.bit.DLC = 8;
    ECanbMboxes.MBOX24.MSGCTRL.bit.RTR = 0;
        EALLOW;
//   ECanbRegs.CANGAM.all = 0x90200000;
//        ECanbLAMRegs.LAM24.all = 0x00000000;
    ECanbMboxes.MBOX0.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX1.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX2.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX3.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX4.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX5.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX6.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX7.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX8.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX9.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX10.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX11.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX12.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX13.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX14.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX15.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX16.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX17.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX18.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX19.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX20.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX21.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX22.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX23.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX24.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX25.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX26.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX27.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX28.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX29.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX30.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX31.MSGCTRL.all = 0x00000000;
        ECanbRegs.CANMIM.all = 0xffffffff;
        ECanbRegs.CANMIL.all = 0;
        ECanbRegs.CANGIF0.all = 0xffffffff;
        ECanbRegs.CANGIM.bit.I0EN = 1;
        EDIS;
        PieCtrlRegs.PIEIER9.bit.INTx7 = 1;
        IER |= M_INT9;
        EINT;
        ERTM;
   j=0x01;
/* Begin transmitting */
while(1)
  // for(i=0; i < TXCOUNT; i++)
   for(t = 0x00;t < 2;t++)
       InitECanb();
       ECanbShadow.CANTRS.all = 0;
      ECanbShadow.CANTRS.bit.TRS25 = 1;             // Set TRS for mailbox under test
       ECanbRegs.CANTRS.all = ECanbShadow.CANTRS.all;
       kk = 0;
       do
                 kk = kk + 1;
              ECanbShadow.CANTA.all = ECanbRegs.CANTA.all;
                } while((ECanbShadow.CANTA.bit.TA25 == 0 ) && (kk < 10000));   // Wait for TA5 bit to be set..
         if( kk < 10000) break;
          if(kk<10000) j++;
       ECanbShadow.CANTA.all = 0;
       ECanbShadow.CANTA.bit.TA25 = 1;                      // Clear TA5
       ECanbRegs.CANTA.all = ECanbShadow.CANTA.all;
    // asm(" ESTOP0");  // Stop here
 楼主| pengf 发表于 2020-5-29 23:29 | 显示全部楼层
void InitECanb(void)                // Initialize eCAN-B module
needed, since only 32-bit access is allowed to these registers. 16-bit access
to these registers could potentially corrupt the register contents or return
false data. This is especially true while writing to/reading from a bit
   EALLOW;                // EALLOW enables access to protected bits
/* Configure eCAN RX and TX pins for CAN operation using eCAN regs*/
    ECanbShadow.CANTIOC.all = ECanbRegs.CANTIOC.all;
    ECanbShadow.CANTIOC.bit.TXFUNC = 1;
    ECanbRegs.CANTIOC.all = ECanbShadow.CANTIOC.all;
    ECanbShadow.CANRIOC.all = ECanbRegs.CANRIOC.all;
    ECanbShadow.CANRIOC.bit.RXFUNC = 1;
    ECanbRegs.CANRIOC.all = ECanbShadow.CANRIOC.all;
/* Configure eCAN for HECC mode - (reqd to access mailboxes 16 thru 31) */
        ECanbShadow.CANMC.all = ECanbRegs.CANMC.all;
        ECanbShadow.CANMC.bit.SCB = 1;
        ECanbRegs.CANMC.all = ECanbShadow.CANMC.all;
/* Initialize all bits of 'Master Control Field' to zero */
// Some bits of MSGCTRL register come up in an unknown state. For proper operation,
// all bits (including reserved bits) of MSGCTRL must be initialized to zero
// TAn, RMPn, GIFn bits are all zero upon reset and are cleared again
//        as a matter of precaution.
        ECanbRegs.CANTA.all        = 0xFFFFFFFF;        /* Clear all TAn bits */
        ECanbRegs.CANRMP.all = 0xFFFFFFFF;        /* Clear all RMPn bits */
        ECanbRegs.CANGIF0.all = 0xFFFFFFFF;        /* Clear all interrupt flag bits */
        ECanbRegs.CANGIF1.all = 0xFFFFFFFF;
        ECanbShadow.CANMC.bit.CCR = 1 ;            // Set CCR = 1
    ECanbShadow.CANES.all = ECanbRegs.CANES.all;
    do
        } while(ECanbShadow.CANES.bit.CCE != 1 );                 // Wait for CCE bit to be  cleared..
    ECanbShadow.CANBTC.all = 0;
    #if (CPU_FRQ_150MHZ)                       // CPU_FRQ_150MHz is defined in DSP2833x_Examples.h
        /* The following block for all 150 MHz SYSCLKOUT (75 MHz CAN clock) - default. Bit rate = 1 Mbps
           See Note at end of file */
                ECanbShadow.CANBTC.bit.BRPREG = 39;
                ECanbShadow.CANBTC.bit.TSEG2REG = 2;
                ECanbShadow.CANBTC.bit.TSEG1REG = 10;
        #endif
        #if (CPU_FRQ_100MHZ)                       // CPU_FRQ_100MHz is defined in DSP2833x_Examples.h
        /* The following block is only for 100 MHz SYSCLKOUT (50 MHz CAN clock). Bit rate = 1 Mbps
            ECanbShadow.CANBTC.bit.BRPREG = 4;
                ECanbShadow.CANBTC.bit.TSEG2REG = 1;
                ECanbShadow.CANBTC.bit.TSEG1REG = 6;
        #endif
    ECanbShadow.CANBTC.bit.SAM = 1;
    ECanbRegs.CANBTC.all = ECanbShadow.CANBTC.all;
        ECanbShadow.CANMC.bit.CCR = 0 ;            // Set CCR = 0
    ECanbShadow.CANMC.bit.SUSP = 0 ;
    ECanbShadow.CANMC.bit.PDR = 0 ;
        ECanbShadow.CANMC.bit.DBO = 0 ;
        ECanbShadow.CANMC.bit.WUBA = 0 ;
        ECanbShadow.CANMC.bit.CDR = 0 ;
        ECanbShadow.CANMC.bit.ABO = 0 ;
        ECanbShadow.CANMC.bit.STM = 0 ;
        ECanbShadow.CANMC.bit.SRES = 0 ;
        ECanbShadow.CANMC.bit.MBNR = 0 ;
    do
    } while(ECanbShadow.CANES.bit.CCE != 0 );                 // Wait for CCE bit to be  cleared..
/* Disable all Mailboxes  */
        ECanbRegs.CANME.all = 0;                // Required before writing the MSGIDs
  //  EDIS;
          ECanbMboxes.MBOX25.MSGID.all = 0x90200000; // Extended Identifier
          ECanbMboxes.MBOX28.MSGID.all = 0x90200000;
/* Configure Mailbox under test as a Transmit mailbox */
   ECanbShadow.CANMD.bit.MD25 = 0;    ///  1: 接收邮箱  0:发送邮箱
   ECanbShadow.CANMD.bit.MD28 = 1;    ///  1: 接收邮箱  0:发送邮箱
/* Enable Mailbox under test */
   ECanbShadow.CANME.bit.ME25 = 1;     ///  1:使能    0:  不使能
  ECanbShadow.CANME.bit.ME28 = 1;     ///  1:使能    0:  不使能
/* Write to DLC field in Master Control reg */
   ECanbMboxes.MBOX25.MSGCTRL.bit.DLC = 8;
   ECanbMboxes.MBOX25.MSGCTRL.bit.RTR = 0;
    ECanbMboxes.MBOX28.MSGCTRL.bit.DLC = 8;
    ECanbMboxes.MBOX28.MSGCTRL.bit.RTR = 0;
/* Write to the mailbox RAM field */
   ECanbMboxes.MBOX25.MDL.all = 0x00000000;
   ECanbMboxes.MBOX25.MDH.all = 0x00610000;
    EDIS;
//  j=0x01;
 楼主| pengf 发表于 2020-5-29 23:32 | 显示全部楼层
interrupt void ECAN0INTB_ISR(void)  // eCAN-B
             int z=0;
           while((ECanbRegs.CANRMP.all != 0x10000000 )&&(z<10000)) z++;
                 ECanbRegs.CANRMP.all = 0x10000000;
                 datah = ECanbMboxes.MBOX28.MDH.all;
                 datal = ECanbMboxes.MBOX28.MDL.all;
                 PieCtrlRegs.PIEACK.bit.ACK9 = 1;
  // Insert ISR Code here
  // To receive more interrupts from this PIE group, acknowledge this interrupt
  // PieCtrlRegs.PIEACK.all = PIEACK_GROUP9;
  // Next two lines for debug only to halt the processor here
  // Remove after inserting ISR Code
//  asm ("      ESTOP0");
//  for(;;);
happy_10 发表于 2020-5-29 23:35 | 显示全部楼层
还有什么现象?
 楼主| pengf 发表于 2020-5-29 23:36 | 显示全部楼层
现在发送应该是成功发送到总线上了,因为将断点设置在ECanbShadow.CANTA.bit.TA25 = 1;                      // Clear TA5
可以看到kk的值小于10000,小于10000表示发送成功,但是我查看CANES.TM 发现这个位的值一直为0,这意味着CAN模块没有发送数据。
这里感觉有点矛盾
wenfen 发表于 2020-5-29 23:38 | 显示全部楼层
接受不到CAN设备发送过来的数据?
 楼主| pengf 发表于 2020-5-29 23:39 | 显示全部楼层
嗯,因为while((ECanbRegs.CANRMP.all != 0x10000000 )&&(z<10000)) z++;
之后的z一直为10000意味着没有收到消息
zwll 发表于 2020-5-29 23:42 | 显示全部楼层
上位机接收下位机应答数据帧时,需要对协议识别码做滤波屏蔽,否则会接收到下位机发送
zhaoxqi 发表于 2020-5-29 23:44 | 显示全部楼层
你有什么打算呢?或者你想知道什么?
 楼主| pengf 发表于 2020-5-29 23:45 | 显示全部楼层
否则会接收到下位机发送
的其它协议的数据帧,上位机通讯协议识别码为 ID 的高 12 位(识别码:0x102)。
 楼主| pengf 发表于 2020-5-29 23:46 | 显示全部楼层
这个滤波屏蔽怎么设置呢?
