[DemoCode下载] ML的低功耗模式下使用PDMA
1139|15
 楼主| 734774645 发表于 2020-5-31 22:01 | 显示全部楼层 |阅读模式
  1. /*---------------------------------------------------------------------------------------------------------*/
  2. /*        */
  3. /* Copyright(c) 2019 Nuvoton Technology Corp. All rights reserved.                                         */
  4. /*        */
  5. /*---------------------------------------------------------------------------------------------------------*/
  6. //***********************************************************************************************************
  7. //  Website: http://www.nuvoton.com
  8. //  E-Mail : MicroC-8bit@nuvoton.com
  9. //***********************************************************************************************************
  10. //***********************************************************************************************************
  11. //  File Function: ML51 simple GPIO toggle out demo code
  12. //***********************************************************************************************************
  13. #include "ML51.h"
  14. /**
  15. * [url=home.php?mod=space&uid=247401]@brief[/url]       Low power run mode Memory to memory function demo
  16. * @param       None
  17. * [url=home.php?mod=space&uid=266161]@return[/url]      None
  18. * [url=home.php?mod=space&uid=1543424]@Details[/url]
  19. */
  20. unsigned char xdata RxDatabuffer[100] _at_ 0x100;
  21. unsigned char xdata finalbuffer _at_ 0x263;
  22. unsigned char i;
  23. void PDMA1_ISR(void) interrupt 21          // Vector [url=home.php?mod=space&uid=72445]@[/url]  0xAB
  24. {
  25.   PDMA_Close(PDMA1);
  26.   clr_DMA1TSR_FDONE;
  27.   clr_DMA1TSR_HDONE;
  28. }
  29. void main (void)
  30. {
  31.     ALL_GPIO_QUASI_MODE;
  32.     for(i=0;i<100;i++)
  33.     {
  34.       RxDatabuffer[i]=i;
  35.     }
  36. /* Define PMDA function as memory to memory, and setting base address */
  37.     PDMA_Open(PDMA1,XRAM_XRAM,0x100,0x80);
  38. /* Define destination memory address */
  39.     PDMA_MTM_DestinationAddress(PDMA1,0x200);
  40. /* Define interrupt after full transfer */
  41.     PDMA_Interrupt_Enable(PDMA1,PDMAFULLINT);
  42.     ENABLE_GLOBAL_INTERRUPT;
  43.
  44.     FsysSelect(FSYS_LIRC);
  45.     set_PCON_LPR;
  46.     PDMA_Run(PDMA1);
  47.     while(1);
  48. }
 楼主| 734774645 发表于 2020-5-31 22:02 | 显示全部楼层
  2. /*        */
  4. /*        */
  14.     unsigned char xdata RxDatabuffer[100] _at_ 0x100;
  15.     unsigned char ct;
  16. /**
  17. * @brief       Low power run mode UART TX or receive demo
  18. * @param       None
  19. * @return      None
  20. * @details
  21. */
  22. void PDMA0_ISR(void) interrupt 20          // Vector @  0xA3
  23. {
  24. /* if need check with XRAM PDMA value, should enable following part */
  25. //  clr_PCON_LPR;
  26. //  FsysSelect(FSYS_HIRC);
  27. /* ******************** */
  28.   PDMA_Close(PDMA0);
  29.   SFRS=0;DMA0TSR=0;
  30. /*only for check PDMA reciverd */
  31. //  while(1)
  32. //  {
  33. //    P14=0;
  34. //    P14=1;
  35. //  }
  36. //  printf (" \n PDMA receiv UART2 RX finish! " );
  37. /* ****** */
  38. }
  39.
  40.
  41. void main (void)
  42. {
  43. #if 1
  44.     MFP_P46_CLKO;
  45.     P46_QUASI_MODE;
  46.     set_CKCON_CLOEN;
  47.
  48.     MFP_P54_UART2_TXD;
  49.     P54_QUASI_MODE;
  50.     LowPower_LIRC_UART2_4800_init();
  51.
  52. /*Enable Low power run mode */
  53.     FsysSelect(FSYS_LIRC);
  54.     set_PCON_LPR;
  55.
  56.     while(1)
  57.     {
  58.       LowPower_UART2_Send_Data(0x55);
  59.       _delay_();
  60.     }
  61. #else
  62.     All_GPIO_QUASI_MODE;
  63.     MFP_P14_GPIO;
  64.
  65. /* Enable UART2 RX */
  66.     MFP_P55_UART2_RXD;
  67.     P55_INPUT_MODE;
  68.     LowPower_LIRC_UART2_4800_init();
  69.
  70. /* Clear XRAM base address area to 00h */
  71.     for(ct=0;ct<10;ct++)
  72.     {
  73.       RxDatabuffer[ct]=0;
  74.     }
  75. /* Define PMDA function as UART RX to memory, define base address and PDMA receive length */
  76.     PDMA_Open(PDMA0,SMCRX,0x100,5);
  77. /* Define interrupt after full transfer */
  78.     PDMA_Interrupt_Enable(PDMA0,PDMAFULLINT);
  79. /* Global interrupt enable */
  80.     ENABLE_GLOBAL_INTERRUPT;
  81. /* Start PDMA transfer */
  82.     PDMA_Run(PDMA0);
  83.
  84. /*Enable Low power run mode */
  85.     FsysSelect(FSYS_LIRC);
  86.     set_PCON_LPR;
  87.
  88.     while(1);
  89. #endif
  90. }
 楼主| 734774645 发表于 2020-5-31 22:03 | 显示全部楼层
ML51 run in low power run mode with enable PDMA function to execute memory to memory function
ML51 run in low power run mode and enable UART2 receive data storage in XRAM with PDMA enable.
598330983 发表于 2020-5-31 22:04 | 显示全部楼层
例子不错,学习学习。
zhuotuzi 发表于 2020-5-31 22:47 | 显示全部楼层
还用到了中断
gejigeji521 发表于 2020-5-31 23:36 来自手机 | 显示全部楼层
支持的运行方式挺多的
xuanhuanzi 发表于 2020-6-2 23:32 | 显示全部楼层
没看太明白,怎么移动位置的
gejigeji521 发表于 2020-6-3 20:52 | 显示全部楼层
我也有楼上的疑问。
antusheng 发表于 2020-6-4 21:18 | 显示全部楼层
我猜就是中断下实现。中断会唤醒低功耗。
antusheng 发表于 2020-6-6 08:58 | 显示全部楼层
体验了一下,这个低功耗真棒。
heimaojingzhang 发表于 2020-6-6 14:41 | 显示全部楼层
非常感谢楼主分享
keaibukelian 发表于 2020-6-6 14:42 | 显示全部楼层
新唐的芯片好强大
labasi 发表于 2020-6-6 14:42 | 显示全部楼层
确实非常不错
paotangsan 发表于 2020-6-6 14:42 | 显示全部楼层
想块块的试试去
renzheshengui 发表于 2020-6-6 14:43 | 显示全部楼层
楼主辛苦了
