[STM32F1] 关于PWM的翻转输出,无法输出波形
794|2
 楼主| cons 发表于 2020-6-2 16:38 | 显示全部楼层 |阅读模式
求大佬们看看这是哪里的问题。
TIM.C
static void TIM3_GPIO_Config(void)
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3 , ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 ;        //定时器TIM3通道1输出
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0 ;     //led灯
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
定时器配置
static void TIM3_Mode_Config(void)
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
  TIM_TimeBaseStructure.TIM_Period = 999;
  TIM_TimeBaseStructure.TIM_Prescaler = 71;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0 ;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 500;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM_OC1Init(TIM3, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM3, ENABLE);
  /* TIM3 enable counter */
  TIM_ClearFlag(TIM3,TIM_IT_CC1);
        TIM_ITConfig(TIM3,TIM_IT_CC1,ENABLE);
        TIM_Cmd(TIM3, ENABLE);
中断配置
void TIM3_NVIC_Configuration(void)
    NVIC_InitTypeDef NVIC_InitStructure;
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
    NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
void TIM3_PWM_Init(void)
        TIM3_GPIO_Config();
        TIM3_Mode_Config();
中断函数
void TIM3_IRQHandler(void)
        u16 temp=0;
        u16 count=0;
        if(TIM_GetITStatus(TIM3,TIM_IT_CC1) != RESET)
                TIM_ClearITPendingBit(TIM3,TIM_IT_CC1);
                count = TIM_GetCapture2(TIM3);
                temp = count + 500;
                TIM_SetCompare2(TIM3, temp);
                time++;
main.c
volatile u32 time = 0;
int main(void)
        TIM3_PWM_Init();
        TIM3_NVIC_Configuration();
        while (1)
                if(time == 2000)
                        time = 0;
                        GPIOB ->ODR ^=GPIO_Pin_0;
香水城 发表于 2020-6-2 19:45 | 显示全部楼层
我看你使用的是比较输出切换模式,希望每500翻转一次对吧,
这样的话,按理应该是可以输出的。 要不你先改成PWM输出模式验证下。
【抱歉,我之前理解错了。】
香水城 发表于 2020-8-31 15:17 | 显示全部楼层
这里有个定时器切换模式应用示例,可以了解下。
STM32定时器比较输出切换模式之应用实例
