读取液晶ID
411|0
 楼主| 第十代火影 发表于 2018-6-27 13:46 | 显示全部楼层 |阅读模式
[table][tr][td]
<div class="blockcode"><div id="code_cEc">
  • uint16_t LCD_ID;
  • void LCD_REG_Config(void)
  • 0XD3
  • The 1st         parameter is dummy data.
  • The 2nd         parameter is LCD module/driver ID.
  • The ID3 can be programmed by MTP function.
  •         Lcd_Delay(0xAFFf<<4);
  •         LCD_ILI9341_CMD(0xD3);
  •         LCD_ID = LCD_RD_data();
  •         if(LCD_ID == 0x9341)
  •         /*  Power control B (CFh)  */
