[STM32F1] 硬件配置
664|18
 楼主| xxrs 发表于 2020-6-21 19:55 | 显示全部楼层 |阅读模式
SPI_SSOutputCmd(SPIx, ENABLE);之后 master的NSS就一直是低电平,用逻辑分析 仪看了。
这个是不是stm32f103的BUG?
goodluck09876 发表于 2020-6-21 19:57 | 显示全部楼层
这个硬件的配置 真没有遇到过,,,一般情况下都是软件来配置
houcs 发表于 2020-6-21 19:58 | 显示全部楼层
我想问如果stm32f103 有这个bug  那么  32f2xx、32f3xx、32f4xx、32f7xx系列的MCU还有没有这个BUG?
supernan 发表于 2020-6-21 20:02 | 显示全部楼层
不要用软件配置,直接初始化IO输出,手动设置片选
supernan 发表于 2020-6-21 20:13 | 显示全部楼层
NSS应该是什么电平。。这个是不是没有配置对。
gongche 发表于 2020-6-21 20:18 | 显示全部楼层
问:使用SPI外设时如何设定NSS为通用IO口?
答:主模式和从模式下均可以由软件或硬件进行NSS管理; 将SPI_CR1寄存器的SSM位置为1时,NSS引脚将被释放出来用作GPIO口; 使用STM32软件库时,初始化SPI外设时,使用如下代码: SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; 如果NSS引脚用于其他外设时,需要使能NSS输出: SPI_SSOutputCmd(SPIx, ENABLE);
答:TM32 SPI NSS无法自动跳变 对于STM32的SPI ,Reference Manual中是给出的schematic如下: 按照标准的SPI协议,当SPI被配置为主机模式后,通过SPI对从设备进行操作时,其NSS应该自动置低,从而选中(使能)从设备;一旦不对从设备进行操作,NSS立刻置为高。 但是,我在实际调试过程中却发现:STM32 SPI NSS无法自动实现跳变。 一旦SPI初始化完成并使能SPI,NSS立刻置低,然后保持不变。 这个问题一直无法解决,直到我在ST官方论坛上看到国外有些技术人员也在讨论这个问题,他们得出的结论是:STM32 SPI NSS无法自动跳变。 RichardE Posted 24-07-2009 at 16:07 Registered on : 11-05-2005 From UK (United Kingdom) Messages : 19 OFF-Line I've just hit this NSS problem. What is good: That the discussion is here on the forum to stop me spending hours trying to work out what I have done wrong. Thanks guys! What is not good: That NSS doesn't behave as expected. What I expected to happen: I'm expecting to see on my scope what I see in Figure 208 of RM008 Reference Manual, i.e. NSS goes high after the transfer. Why a working NSS would be very helpful: I'm using the SPI (with DMA) to clock data into shift registers. If NSS went high after the transfer (as indicated by Figure 208), I could use that edge as the strobe to latch the data across into the shift register outputs. Everything would be done by the peripheral. Fire and forget. As it is with the broken NSS, I have to generate an interrupt and use that to strobe the gpio output (I hate controlling gpio from within interrupt routines). Any update as to when this will be fixed? ST官方技术人员也证实:STM32 SPI NSS是不会自动置位和复位的。按照官方说法,ST已经将其列入了改进计划。 对于这个问题,可以采用下面的方法解决: 在SPI初始化时,采用NSS soft模式,然后使能NSS输出功能。从而将NSS当做GPIO使用,通过软件set和reset来实现NSS的置位和复位。
gongche 发表于 2020-6-21 20:23 | 显示全部楼层
/* SPI1 configuration ------------------------------------------------------*/
SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
// SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
//SPI_FirstBit_MSB; SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI1, &SPI_InitStructure);
/*Enable SPI1.NSS as a GPIO*/ SPI_SSOutputCmd(SPI1, ENABLE);
/*Configure PA.4(NSS)--------------------------------------------*/
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
gongche 发表于 2020-6-21 20:28 | 显示全部楼层
通过将NSS配置为GPIO,在通过SPI操作从设备时,就可以通过软件来选中和释放从设备了。虽然比起硬件自动置位要麻烦,但问题毕竟解决了。 进一步阅读长达900页的Manual,我发现,文中对于SPI hard模式的描述并非大多数人所认为的硬件SPI,原文如下: Slave select (NSS) pin management There are two NSS modes: ● Software NSS mode: this mode is enabled by setting the SSM bit in the SPI_CR1 register (see Figure 209). In this mode, the external NSS pin is free for other application uses and the internal NSS signal level is driven by writing to the SSI bit in the SPI_CR1 register. ● Hardware NSS mode: there are two cases: – NSS output is enabled: when the STM32F20xxx is operating as a Master and the NSS output is enabled through the SSOE bit in the SPI_CR2 register, the NSS pin is driven low and all the NSS pins of devices connected to the Master NSS pin see a low level and become slaves when they are configured in NSS hardware mode. When an SPI wants to broadcast a message, it has to pull NSS low to inform all others that there is now a master for the bus. If it fails to pull NSS low, this means that there is another master communicating, and a Hard Fault error occurs. – NSS output is disabled: the multimaster capability is allowed. 当SPI配置为hard模式后,通过检测NSS可以实现的是自身主机和从机模式的切换,而不是大多数人所认为的自动NSS。。。也就是说:在一个多SPI系统中,STM32 SPI通过NSS检测,一旦发现系统中无NSS低信号,自己就输出低,从而成为主机;当系统中有NSS低信号时(及已经有其它SPI宣布为主机),自己就配置为从机。 所谓的hard模式的NSS,实际就是为了实现多机间通信的。 小结: 望文生义很可怕,Manual要仔细研读。 STM32的SPI NSS不论是配置为soft还是hard都是无法自动置位的,但这却是大多数应用所需要的。正如ST 论坛上RichardE所说:“Everything would be done by the peripheral. Fire and forget.”
gongche 发表于 2020-6-21 20:31 | 显示全部楼层
以上转载,不知道对不对。
houcs 发表于 2020-6-21 20:34 | 显示全部楼层
手册没个时序图?
chenjunt 发表于 2020-6-21 20:42 | 显示全部楼层
按理说没啥问题
tian111 发表于 2020-6-21 20:46 | 显示全部楼层
没用过这个引脚 都是自己用io口
zhuww 发表于 2020-6-21 20:52 | 显示全部楼层
是不是一直没有发送出去呢
 楼主| xxrs 发表于 2020-6-21 20:55 | 显示全部楼层
搞定了,呵呵,犯了低级错误……
wowu 发表于 2020-7-9 17:04 | 显示全部楼层
如何配置的呢
xiaoqizi 发表于 2020-7-9 17:05 | 显示全部楼层
极有可能和硬件连接有关系
木木guainv 发表于 2020-7-9 17:05 | 显示全部楼层
出现bug的面小
磨砂 发表于 2020-7-9 17:05 | 显示全部楼层
不连接别的外设 你再试试看
晓伍 发表于 2020-7-9 17:06 | 显示全部楼层
楼主找到问题了吗
