急!!!使用开发板 做DAC电压输出,在PA4口测量始终为参考电压(3.26V)
603|0
 楼主| スモモ 发表于 2018-7-4 08:56 | 显示全部楼层 |阅读模式
#include "dac.h"
#include "stm32f10x.h"
void DAC_CH_CONFIG()
        DAC_InitTypeDef DAC_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE );
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE );
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
    DAC_InitStructure.DAC_Trigger = DAC_Trigger_Software ; //软件触发
        //以下两句的作用为关闭DAC端口的输出三角波形功能以及关闭其输出波形的电压幅值
        DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
        DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude=DAC_LFSRUnmask_Bit0;
        //关闭缓存,DAC端口不接负载时可不用缓存
        DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable;
        DAC_Init( DAC_Channel_1, &DAC_InitStructure ); //初始化
        DAC_Cmd(DAC_Channel_1, ENABLE); //使能DAC1 通
        DAC_SetChannel1Data(DAC_Align_12b_R, 0x0000); //写入初始值0
        DAC_SoftwareTriggerCmd(DAC_Channel_1, ENABLE); ///软件触发转换
void DAC_SET()
        DAC_SetChannel1Data(DAC_Align_12b_R,1000);
main 函数:
int main(void)
        DAC_CH_CONFIG();
        DAC_SET();
    while(1)
改变DAC_SetChannel1Data(DAC_Align_12b_R,1000); 中的参数值,PA4口输出 不变,用万用表测量的电压始终为3.26V, 按理说参数设置为1000时,端口输出电压应该为0.79V 啊 !
CPU :STM32F103VET6  各位大侠 ,帮忙看下啊,谢谢!
