stm32F4用ADC1和DMA得到的数据都是大于4095
690|0
 楼主| 一亚麻怡 发表于 2018-7-6 09:58 | 显示全部楼层 |阅读模式
参考网上的说法加上 ADC_InitStructure.ADC_ExternalTrigConv = 0;也还是没用。是什么原因呢?下面是我的初始化程序和witch窗口的数据
void  Adc_Init(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
        ADC_CommonInitTypeDef ADC_CommonInitStructure;
        ADC_InitTypeDef       ADC_InitStructure;
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);//使能GPIOA时钟
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE); //使能ADC1时钟
  //先初始化ADC1通道10 IO口
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;//PC0 通道10
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;//模拟输入
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;//不带上下拉
  GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_ADC1,ENABLE);          //ADC1复位
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_ADC1,DISABLE);        //复位结束
        /*ADC通用设置*/
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;//独立模式
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;//两个采样阶段之间的延迟5个时钟
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled; //DMA失能
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div4;//预分频4分频。ADCCLK=PCLK2/4=84/4=21Mhz,ADC时钟最好不要超过36Mhz
  ADC_CommonInit(&ADC_CommonInitStructure);//初始化
        /*ADC1设置*/
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;//12位模式
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;//非扫描模式
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//开启连续转换
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;//禁止触发检测,使用软件触发
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//右对齐
  ADC_InitStructure.ADC_NbrOfConversion = 1;//1个转换在规则序列中 也就是只转换规则序列1
  ADC_Init(ADC1, &ADC_InitStructure);//ADC初始化
  ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_480Cycles );        //ADC1,ADC通道,480个周期,提高采样时间可以提高精确度
        ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);        // 使能DMA请求 after last transfer (Single-ADC mode)
        ADC_DMACmd(ADC1, ENABLE);        // 使能ADC DMA
        ADC_Cmd(ADC1, ENABLE);          // 使能ADC
        ADC_SoftwareStartConv(ADC1);        //开始adc转换,软件触发
