STM32F407ZGT6 TIM8 CH2/3 PWM 互补不输出
486|0
 楼主| 你画我瞎 发表于 2018-7-9 13:46 | 显示全部楼层 |阅读模式
下面是程序
TIM8定时器好像是工作了,但,PWM无输出
void IO_Configuration(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
        GPIO_InitStructure.GPIO_Pin = GPIO_PinSource0|GPIO_PinSource1;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        GPIO_Init(GPIOB,&GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOC,GPIO_PinSource7|GPIO_PinSource8,GPIO_AF_TIM8);
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource0|GPIO_PinSource1,GPIO_AF_TIM8);
void TIM_Configuration(void)
  TIM_TimeBaseInitTypeDef TIM_TimeBaseStruct;
  TIM_DeInit(TIM8);
  TIM_TimeBaseStruct.TIM_Period                      = 7000;
  TIM_TimeBaseStruct.TIM_Prescaler            = 0;
  TIM_TimeBaseStruct.TIM_ClockDivision        = TIM_CKD_DIV1;
  TIM_TimeBaseStruct.TIM_CounterMode       = TIM_CounterMode_Up;
  TIM_TimeBaseStruct.TIM_RepetitionCounter  = 0;
  TIM_TimeBaseInit(TIM8, &TIM_TimeBaseStruct);
void PWM_Configuration(void)
        TIM_OCInitTypeDef        TIM_OCInitStructure;
        TIM_BDTRInitTypeDef      TIM8_BDTRInitStruct;
        TIM_OCInitStructure.TIM_OCMode                  = TIM_OCMode_PWM1;
        TIM_OCInitStructure.TIM_OutputState             = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_OutputNState           = TIM_OutputNState_Enable;
        TIM_OCInitStructure.TIM_Pulse                        = 0;
        TIM_OCInitStructure.TIM_OCPolarity                   = TIM_OCPolarity_High;
        TIM_OCInitStructure.TIM_OCNPolarity                  = TIM_OCNPolarity_High;
        TIM_OCInitStructure.TIM_OCIdleState                  = TIM_OCIdleState_Reset;
        TIM_OCInitStructure.TIM_OCNIdleState                 = TIM_OCIdleState_Reset;
        TIM_OC2Init(TIM8, &TIM_OCInitStructure);
        TIM_OC3Init(TIM8, &TIM_OCInitStructure);
        TIM_OC2PreloadConfig(TIM8, TIM_OCPreload_Enable);
        TIM_OC3PreloadConfig(TIM8, TIM_OCPreload_Enable);
        TIM8_BDTRInitStruct.TIM_OSSRState                         = TIM_OSSRState_Enable;
        TIM8_BDTRInitStruct.TIM_OSSIState                         = TIM_OSSIState_Enable;
        TIM8_BDTRInitStruct.TIM_LOCKLevel                         = TIM_LOCKLevel_OFF;
        TIM8_BDTRInitStruct.TIM_DeadTime                          = 0x10;
        TIM8_BDTRInitStruct.TIM_Break                             = TIM_Break_Disable;
        TIM8_BDTRInitStruct.TIM_BreakPolarity         = TIM_BreakPolarity_High;
        TIM8_BDTRInitStruct.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
        TIM_BDTRConfig(TIM8, &TIM8_BDTRInitStruct);
        TIM_ARRPreloadConfig(TIM8, ENABLE);
        TIM_ClearITPendingBit(TIM8,TIM_IT_Update);
        TIM_ITConfig(TIM8,TIM_IT_Update,ENABLE);
        TIM_CtrlPWMOutputs(TIM8, ENABLE);
        TIM_CCxCmd(TIM8,TIM_Channel_2,TIM_CCx_Enable);
        TIM_CCxNCmd(TIM8,TIM_Channel_2,TIM_CCxN_Enable);
        TIM_CCxCmd(TIM8,TIM_Channel_3,TIM_CCx_Enable);
        TIM_CCxNCmd(TIM8,TIM_Channel_3,TIM_CCxN_Enable);
