通过电阻分压得到2V电压 接到1 和4管脚 别直接接 两个脚上各串一个电阻<br />这是资料上写的:<br />Figure 5-6. An ac-coupled, single-supply,<br />in-amp circuit. For maximum dynamic range,<br />set VCM to the center of the maximum input<br />range. VREF is typically set to VS/2.<br /><br />VCM 就是偏置 图传不上来
