[MCU] 请问是代码有问题吗?
825|5
 楼主| zyf部长 发表于 2020-6-28 22:36 | 显示全部楼层 |阅读模式
其中 Udc给定为540,Ts为中断时间0.000125s,Ualpha和Ubeta都有输入但是CMPA一直输出都是0,
float temp;
float X,Y,Z, t1,t2;
Uint16 A,B,C,N,Sector;
float Ta, Tb, Tc;
float K=1.73205081;//sqrt(3)
X= K*p->Ubeta/p->Vdc*p->T;
Y=(K*p->Ubeta+3*p->Ualpha)/(2*p->Vdc)*p->T;
Z=(K*p->Ubeta-3*p->Ualpha)/(2*p->Vdc)*p->T;
if(p->Ubeta>0)
   {A=1;}
else
   {A=0;}
if( (K*p->Ualpha-p->Ubeta)>0 )
   {B=1;}
else
   {B=0;}
if((-K*p->Ualpha-p->Ubeta)>0)
   {C=1;}
else
   {C=0;}
N=A+2*B+4*C;
switch(N)
case 1:{Sector=2;break;}
case 2:{Sector=6;break;}
case 3:{Sector=1;break;}
case 4:{Sector=4;break;}
case 5:{Sector=3;break;}
case 6:{Sector=5;break;}
default:{;}
switch(Sector)
case 1: {t1=-Z; t2= X;break;}
case 2: {t1= Z; t2= Y;break;}
case 3: {t1= X; t2=-Y;break;}
case 4: {t1=-X; t2= Z;break;}
case 5: {t1=-Y; t2=-Z;break;}
case 6: {t1= Y; t2=-X;break;}
  default:{;}
if((t1+t2)>p->T)//对过调制情况进行调整
  temp=t1+t2;
  t1=t1*p->T/temp;
  t2=t2*p->T/temp;
Ta=(p->T-t1-t2)/4;//作用时间分配
Tb=Ta+(t1/2);
Tc=Tb+(t2/2);
switch(Sector)
        case 1: {p->Tcmpa=Ta; p->Tcmpb=Tb; p->Tcmpc=Tc; break;}
        case 2: {p->Tcmpa=Tb; p->Tcmpb=Ta; p->Tcmpc=Tc; break;}
        case 3: {p->Tcmpa=Tc; p->Tcmpb=Ta; p->Tcmpc=Tb; break;}
        case 4: {p->Tcmpa=Tc; p->Tcmpb=Tb; p->Tcmpc=Ta; break;}
        case 5: {p->Tcmpa=Tb; p->Tcmpb=Tc; p->Tcmpc=Ta; break;}
        case 6: {p->Tcmpa=Ta; p->Tcmpb=Tc; p->Tcmpc=Tb; break;}
    default:{;}
 楼主| zyf部长 发表于 2020-6-28 22:42 | 显示全部楼层
EPwm1Regs.CMPA.half.CMPA = (int)(2.0*p->PeriodMax*p->Tcmpa);
EPwm2Regs.CMPA.half.CMPA = (int)(2.0*p->PeriodMax*p->Tcmpb);
EPwm3Regs.CMPA.half.CMPA = (int)(2.0*p->PeriodMax*p->Tcmpc);
zhuhuis 发表于 2020-6-28 22:45 | 显示全部楼层
先把捕获中断打开   看看能不能触发进入中断
 楼主| zyf部长 发表于 2020-6-28 22:47 | 显示全部楼层
中断可以的,中间变量值都有编号就是值非常小
zhangmangui 发表于 2020-6-28 22:49 | 显示全部楼层
就这些代码看不出来吧   CMPA是不是配置的问题
 楼主| zyf部长 发表于 2020-6-28 22:50 | 显示全部楼层
好的,我明天去单位试一下,多谢各位大侠了哈
