分享模拟串口RS485代码【YS8156B氨气传感器等】MODBUS 协议(RTU 方式)
382|0
 楼主| 卡拉瓦乔 发表于 2018-7-10 15:44 | 显示全部楼层 |阅读模式
适用于某些工业级O2/CO2/NH3等测量传感器
////crc16.c////
//CRC16校验
    const unsigned char auchCRCHi[] = {
        0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
        0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
        0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
        0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
        0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
        0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
        0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
        0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
        0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
        0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
        0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
    const unsigned char auchCRCLo[] = {
        0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06,
        0x07, 0xC7, 0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD,
        0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,
        0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A,
        0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC, 0x14, 0xD4,
        0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
        0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3,
        0xF2, 0x32, 0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4,
        0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,
        0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29,
        0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF, 0x2D, 0xED,
        0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
        0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60,
        0x61, 0xA1, 0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67,
        0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,
        0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68,
        0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA, 0xBE, 0x7E,
        0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
        0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71,
        0x70, 0xB0, 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92,
        0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
        0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B,
        0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89, 0x4B, 0x8B,
        0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
        0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42,
        0x43, 0x83, 0x41, 0x81, 0x80, 0x40
unsigned short crc16(unsigned char *puchMsg, unsigned short usDataLen){
    unsigned char uchCRCHi = 0xFF ;
    unsigned char uchCRCLo = 0xFF ;
    unsigned int uIndex ;
    while (usDataLen--){
         uIndex = uchCRCHi ^ *puchMsg++ ;
         uchCRCHi = uchCRCLo ^ auchCRCHi[uIndex] ;
         uchCRCLo = auchCRCLo[uIndex] ;
    return (uchCRCHi << 8 | uchCRCLo) ;
////CO2_RS485.h////
#ifndef __CO2_RS485_H
#define __CO2_RS485_H
#include "stm32f4xx_conf.h"
#include "sys.h"
#include "delay.h"
#include "usart.h"
//如果使用ucos,则包括下面的头文件即可.
#if SYSTEM_SUPPORT_OS
#include "includes.h"  //ucos 使用
#endif
#define CO2_RS485_RX         PAin(3)
#define CO2_RS485_TX         PAout(2)
#define CO2_RS485_TX_EN      PGout(8)    //485模式控制.0,接收;1,发送.
#define BOUND_TIME_DIV2  52  //9600波特率延时为104us,可能需要修改,因为时钟选取的HSE的频率可能有偏移
extern u8 CO2_RS485_RX_BUF[7];      //接收缓冲,7个字节
extern u8 CO2_RS485_RX_LEN;       //接收到的数据长度
void CO2_RS485_init(void);
void CO2_RS485_sendInstruction(void);
void CO2_RS485_getOneByte(void);
u16  CO2_RS485_getValue(void);//实际值单位ppm(百万分之一)
unsigned short crc16(unsigned char *puchMsg, unsigned short usDataLen);
#endif
////CO2_RS485.c////
#include "CO2_RS485.h"
u8 CO2_RS485_RX_LEN=0;       //接收到的数据长度
void CO2_RS485_init(void){
    GPIO_InitTypeDef   GPIO_InitStructure;
    EXTI_InitTypeDef   EXTI_InitStructure;
    NVIC_InitTypeDef   NVIC_InitStructure;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA |RCC_AHB1Periph_GPIOG,ENABLE);//使能GPIOK时钟
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);//使能SYSCFG时钟
    //GPIO初始化
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
    GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_OUT;      //普通输出模式
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;      //推挽输出
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;  //100MHz
    GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;       //上拉
    GPIO_Init(GPIOG, &GPIO_InitStructure);              //初始化
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
    GPIO_Init(GPIOA, &GPIO_InitStructure);              //初始化
    //CO2_RS485_TX_EN=0;//设置为接收模式
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;//普通输入模式
    GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化
    //配置 GPIO 与中断线的映射关系
    SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, EXTI_PinSource3);//PK3 连接到中断线3
    //配置EXTI_Line3
    EXTI_InitStructure.EXTI_Line = EXTI_Line3;
    EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;//中断事件
    EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;//下降沿触发
    EXTI_InitStructure.EXTI_LineCmd = ENABLE;//中断线使能
    EXTI_Init(&EXTI_InitStructure);//配置
    //配置中断分组( NVIC),并使能中断
    NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQn;//外部中断3
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;//抢占优先级2
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;//子优先级2
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;//使能外部中断通道
    NVIC_Init(&NVIC_InitStructure);//配置
//已在头文件定义
//#define CO2_RS485_RX         PKin(3)
//#define BOUND_TIME_DIV2  52  //9600波特率延时为104us
//u8 CO2_RS485_RX_BUF[7];      //接收缓冲,7个字节
//u8 CO2_RS485_RX_LEN=0;       //接收到的数据长度
//外部中断3服务程序
//符合标准MODBUS 协议(RTU 方式),通讯波特率固定为9600,1个起始位,8个数据位,无效验位,1个停止位。//
void EXTI3_IRQHandler(void){
#if SYSTEM_SUPPORT_OS //如果SYSTEM_SUPPORT_OS为真,则需要支持OS.
    OSIntEnter();
#endif
    NVIC_DisableIRQ(EXTI3_IRQn);//中断除能
     CO2_RS485_getOneByte();
    NVIC_EnableIRQ(EXTI3_IRQn);//中断使能
     EXTI_ClearITPendingBit(EXTI_Line3);//清除LINE3上的中断标志位
    OSIntExit();
#endif
//已在头文件定义
//#define CO2_RS485_TX         PKout(4)
//#define CO2_RS485_TX_EN      PKout(5)    //485模式控制.0,接收;1,发送.
void CO2_RS485_getOneByte(void){
    u8 i;
    delay_us(BOUND_TIME_DIV2);delay_us(BOUND_TIME_DIV2);
    //8个数据位,低位在前
    for(i=0;i<8;i++){
        CO2_RS485_RX_BUF[CO2_RS485_RX_LEN] = (CO2_RS485_RX_BUF[CO2_RS485_RX_LEN] & (u8)(~(1<<i))) | (u8)CO2_RS485_RX<<i;
        //if(CO2_RS485_RX) buf=1;
        //else buf=0;
    //无奇偶校验位
    //1个停止位
    CO2_RS485_RX_LEN++;
void CO2_RS485_sendInstruction(void){
