我用STM32F103VCT6写了一个编码器的程序,拉线编码器。
不准。比如,拉起来脉冲个数200,松开按说应该是0,起码0左右。
可是不是0,差得远。也就是说检测到的脉冲增加的值和减少的值不一样,误差比较大。
电路:
代码:- //定时器3通道1输入捕获配置
- TIM_ICInitTypeDef TIM3_ICInitStructure;
- void TIM3_Cap_Init(u16 arr,u16 psc)
- GPIO_InitTypeDef GPIO_InitStructure;
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- NVIC_InitTypeDef NVIC_InitStructure;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //使能TIM3时钟
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //使能GPIOC时钟
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7; //PC6,C7 清除之前设置
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //上拉输入
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- GPIO_PinRemapConfig(GPIO_FullRemap_TIM3, ENABLE);
- GPIO_SetBits(GPIOC,GPIO_Pin_6);
- GPIO_SetBits(GPIOC,GPIO_Pin_7);
- //初始化定时器5 TIM5
- TIM_TimeBaseStructure.TIM_Period = arr; //设定计数器自动重装值
- TIM_TimeBaseStructure.TIM_Prescaler =psc; //预分频器
- TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式
- TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
- //初始化TIM5输入捕获参数
- TIM3_ICInitStructure.TIM_Channel = TIM_Channel_1; //CC1S=01 选择输入端 IC1映射到TI1上
- TIM3_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; //上升沿捕获
- TIM3_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到TI1上
- TIM3_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //配置输入分频,不分频
- TIM3_ICInitStructure.TIM_ICFilter = 0x00;//IC1F=0000 配置输入滤波器 不滤波
- TIM_ICInit(TIM3, &TIM3_ICInitStructure);
- //中断分组初始化
- NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; //TIM3中断
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; //先占优先级2级
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //从优先级0级
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
- NVIC_Init(&NVIC_InitStructure); //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器
- TIM_ITConfig(TIM3,TIM_IT_Update|TIM_IT_CC1,ENABLE);//允许更新中断 ,允许CC1IE捕获中断
- TIM_Cmd(TIM3,ENABLE ); //使能定时器5
- u8 TIM3CH1_CAPTURE_STA=0; //输入捕获状态
- u16 TIM3CH1_CAPTURE_VAL; //输入捕获值
- //定时器5中断服务程序
- void TIM3_IRQHandler(void)
- if((TIM3CH1_CAPTURE_STA&0X80)==0)//还未成功捕获
- if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)
- if(TIM3CH1_CAPTURE_STA&0X40)//已经捕获到高电平了
- if((TIM3CH1_CAPTURE_STA&0X3F)==0X3F)//高电平太长了
- TIM3CH1_CAPTURE_STA|=0X80;//标记成功捕获了一次
- TIM3CH1_CAPTURE_VAL=0XFFFF;
- }else TIM3CH1_CAPTURE_STA++;
- if (TIM_GetITStatus(TIM3, TIM_IT_CC1) != RESET)//捕获1发生捕获事件
- if(TIM3CH1_CAPTURE_STA&0X40) //捕获到一个下降沿
- if(GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_7)==1)
- Encoder.LongInt++;
- else
- Encoder.LongInt--;
- TIM3CH1_CAPTURE_STA|=0X80; //标记成功捕获到一次高电平脉宽
- TIM3CH1_CAPTURE_VAL=TIM_GetCapture1(TIM3);
- TIM_OC1PolarityConfig(TIM3,TIM_ICPolarity_Rising); //CC1P=0 设置为上升沿捕获
- }else //还未开始,第一次捕获上升沿
- TIM3CH1_CAPTURE_STA=0; //清空
- TIM3CH1_CAPTURE_VAL=0;
- TIM_SetCounter(TIM3,0);
- TIM3CH1_CAPTURE_STA|=0X40; //标记捕获到了上升沿
- TIM_OC1PolarityConfig(TIM3,TIM_ICPolarity_Falling); //CC1P=1 设置为下降沿捕获
- TIM_ClearITPendingBit(TIM3, TIM_IT_CC1|TIM_IT_Update); //清除中断标志位
- TIM3_Cap_Init(0XFFFF,36-1); //以2Mhz的频率计数
端口配置的上拉输入,还是应该配置为复用?
如果配置为复用,那管脚还能作为IO口使用吗?谢谢
