stm32f767串口中断USART_IRQHandler()有错误,求指点
762|0
 楼主| 丑帅丑帅的 发表于 2018-7-14 11:16 | 显示全部楼层 |阅读模式
程序如下:
1.usart.c程序
#include "usart.h"
#include "gpio.h"
#include "stm32f7xx_hal.h"
/* USER CODE BEGIN 0 */
uint8_t aRxBuffer[RXBUFFERSIZE];   //定义全局变量“aRxBuffer[RXBUFFERSIZE]”为HAL库UASRT函数接收缓冲区
uint16_t USART_RX_STA=0;           //定义接收数据标识符
uint8_t USART_RX_BUF[USART_RX_LEN];//定义接收数据的最大缓存
/* USER CODE END 0 */
UART_HandleTypeDef huart2;
/* USART2 init function */
void MX_USART2_UART_Init(void)
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 9600;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  huart2.Init.StopBits = UART_STOPBITS_1;
  huart2.Init.Parity = UART_PARITY_NONE;
  huart2.Init.Mode = UART_MODE_TX_RX;
  huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  huart2.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  huart2.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  //HAL_UART_Init(&huart2);//HAL_UART_Init()会使能UART1
  if (HAL_UART_Init(&huart2) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
  //开启接收中断,同时设置接收的缓冲以及接收缓冲接收的最大数据量
  HAL_UART_Receive_IT(&huart2,(uint8_t *)aRxBuffer,RXBUFFERSIZE);
void HAL_UART_MspInit(UART_HandleTypeDef* uartHandle)
  GPIO_InitTypeDef GPIO_InitStruct;
  if(uartHandle->Instance==USART2)
  /* USER CODE BEGIN USART2_MspInit 0 */
  /* USER CODE END USART2_MspInit 0 */
    /* USART2 clock enable */
    __HAL_RCC_USART2_CLK_ENABLE();
    /**USART2 GPIO Configuration
    PD5     ------> USART2_TX
    PD6     ------> USART2_RX
    GPIO_InitStruct.Pin = GPIO_PIN_5|GPIO_PIN_6;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF7_USART2;
    HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
    /* USART2 interrupt Init */
    HAL_NVIC_SetPriority(USART2_IRQn, 1, 0);//设置抢占优先级3,子优先级3
    HAL_NVIC_EnableIRQ(USART2_IRQn);        //使能USART2中断通道
  /* USER CODE BEGIN USART2_MspInit 1 */
  /* USER CODE END USART2_MspInit 1 */
void HAL_UART_MspDeInit(UART_HandleTypeDef* uartHandle)
  /* USER CODE BEGIN USART2_MspDeInit 0 */
  /* USER CODE END USART2_MspDeInit 0 */
    /* Peripheral clock disable */
    __HAL_RCC_USART2_CLK_DISABLE();
    HAL_GPIO_DeInit(GPIOD, GPIO_PIN_5|GPIO_PIN_6);
    /* USART2 interrupt Deinit */
    HAL_NVIC_DisableIRQ(USART2_IRQn);
  /* USER CODE BEGIN USART2_MspDeInit 1 */
  /* USER CODE END USART2_MspDeInit 1 */
/* USER CODE BEGIN 1 */
//数据处理函数
void HAL_UART_RxCpltCallback(UART_HandleTypeDef*huart)
    //1.判断接收标识符“USART_RX_STA”bit15是否为1,进而判断接收是否完成
    if((USART_RX_STA & 0x8000)==0)
        //1.1判断接收标识符“USART_RX_STA”bit14是否为1,进而判断是否收到“0x0d”
        if(USART_RX_STA & 0x4000)
            if(aRxBuffer[0] != 0x0a )USART_RX_STA=0;
            else USART_RX_STA |= 0x8000;
        else
            if(aRxBuffer[0] == 0x0d)USART_RX_STA |= 0x4000;
            else
              USART_RX_BUF[USART_RX_STA & 0x3FFF] = aRxBuffer[0];
              USART_RX_STA++;
              //判断接收的数据个数是否超过缓存区的长度
              if(USART_RX_STA > (USART_RX_LEN-1))USART_RX_STA = 0;
//中断函数
void huart2_IRQHandler(void)
    uint32_t timeout = 0;
    uint32_t maxDelay = 0x1FFFF;
    HAL_UART_IRQHandler(&huart2);//调用HAL库公用中断处理函数
    timeout=0;
    //判断串口是否就绪,如果没有就等待就绪
    while(HAL_UART_GetState(&huart2)!= HAL_UART_STATE_READY)
        timeout++;//超时处理
        if(timeout > maxDelay) break;
    timeout = 0;
    //一次处理完成之后,重新开始中断并设置RxXferCount为1
    while(HAL_UART_Receive_IT(&huart2,(uint8_t *)aRxBuffer,RXBUFFERSIZE) != HAL_OK)
        timeout++;//超时处理
2.main.c如下
while(1)
      if(USART_RX_STA&0x8000)
          len=USART_RX_STA&0x3ffff;//得到此次接收到的数据长度
          HAL_UART_Transmit(&huart2,(uint8_t *)USART_RX_BUF,len,1000);//发送接收到的信息
          while(__HAL_UART_GET_FLAG(&huart2,UART_FLAG_TC)!=SET);      //等待发送结束
          USART_RX_STA=0;
          HAL_GPIO_WritePin(GPIOD,GPIO_PIN_15,GPIO_PIN_RESET);
          HAL_UART_Transmit(&huart2,TxData1,8,1000);
      else
          times++;
            if(times % 100000 == 0)
3.出现的错误:接收第一个字符后,跳入void HAL_UART_IRQHandler(UART_HandleTypeDef *huart)函数下面的判断语句,从而跳出接收中断。
if (((huart->ErrorCode & HAL_UART_ERROR_ORE) != RESET) ||
          (HAL_IS_BIT_SET(huart->Instance->CR3, USART_CR3_DMAR)))
        /* Blocking error : transfer is aborted
           Set the UART state ready to be able to start again the process,
           Disable Rx Interrupts, and disable Rx DMA request, if ongoing */
        UART_EndRxTransfer(huart);
初来乍到,求各路大神指点迷津,先行谢过!
