CH452程序调试分析
412|0
 楼主| 小蘭 发表于 2018-7-14 14:56 | 显示全部楼层 |阅读模式
[mw_shl_code=c,true]#include "myiic.h"
#include "delay.h"
//??????IIC
void IIC_Init(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);//????GPIOB?±??
  //GPIOB8,B9???????è??
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//???¨????????
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//???ì????
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//????
  GPIO_Init(GPIOB, &GPIO_InitStructure);//??????
        IIC_SCL=1;
        IIC_SDA=1;
//?ú?úIIC????????
void IIC_Start(void)
        SDA_OUT();     //sda??????
        IIC_SDA=1;
        IIC_SCL=1;
        delay_us(4);
        IIC_SDA=0;//START:when CLK is high,DATA change form high to low
        delay_us(4);
        IIC_SCL=0;//??×?I2C×?????×?±?·????ò????????
//?ú?úIIC????????
void IIC_Stop(void)
        SDA_OUT();//sda??????
        IIC_SCL=0;
        IIC_SDA=0;//STOP:when CLK is high DATA change form low to high
        delay_us(4);
        IIC_SCL=1;
        IIC_SDA=1;//·???I2C×????á??????
        delay_us(4);
//·???????1???????????§°?
//        0??????????????
u8 IIC_Wait_Ack(void)
        u8 ucErrTime=0;
        SDA_IN();      //SDA?è????????
        IIC_SDA=1;delay_us(1);
        IIC_SCL=1;delay_us(1);
        while(READ_SDA)
                ucErrTime++;
                if(ucErrTime>250)
                        IIC_Stop();
                        return 1;
        IIC_SCL=0;//?±??????0
        return 0;
//?ú?úACK????
void IIC_Ack(void)
        IIC_SCL=0;
        SDA_OUT();
        IIC_SDA=0;
        delay_us(2);
        IIC_SCL=1;
        delay_us(2);
        IIC_SCL=0;
//???ú?úACK????
void IIC_NAck(void)
        IIC_SCL=0;
        SDA_OUT();
        IIC_SDA=1;
        delay_us(2);
        IIC_SCL=1;
        delay_us(2);
        IIC_SCL=0;
//IIC·???????×???
//·??????ú????????
//1????????
//0????????
void IIC_Send_Byte(u8 txd)
    u8 t;
        SDA_OUT();
    IIC_SCL=0;//?????±??????????????
    for(t=0;t<8;t++)
        IIC_SDA=(txd&0x80)>>7;
        txd<<=1;
                delay_us(2);   //??TEA5767?????????±????±?????
                IIC_SCL=1;
                delay_us(2);
                IIC_SCL=0;
                delay_us(2);
        IIC_SDA=1;
        delay_us(2);
        IIC_SCL=1;
        delay_us(2);
        IIC_SCL=0;
        delay_us(2);
//??1??×?????ack=1?±??·???ACK??ack=0??·???nACK
u8 IIC_Read_Byte(unsigned char ack)
        unsigned char i,receive=0;
        SDA_IN();//SDA?è????????
    for(i=0;i<8;i++ )
        IIC_SCL=0;
        delay_us(2);
                IIC_SCL=1;
        receive<<=1;
        if(READ_SDA)receive++;
                delay_us(1);
    if (!ack)
        IIC_NAck();//·???nACK
    else
        IIC_Ack(); //·???ACK
    return receive;
void CH452_Write(unsigned int cmd)        //???ü??
         IIC_Start();                       /*????×???*/
         IIC_Send_Byte(((unsigned char)(cmd>>7)&CH452_I2C_MASK)|CH452_I2C_ADDR1);
            IIC_Send_Byte((unsigned char)cmd);     /*·???????*/
           IIC_Stop();;                 /*?á??×???*/
unsigned char CH452_Read()
    unsigned char keycode;
           IIC_Start();                      //Send the Start Bit
          IIC_Send_Byte(0x61);                    //??°?±?
          keycode=IIC_Read_Byte(0);   //????????
          IIC_Stop();                 //?á??×???
          return(keycode);
void LEDS_Intial()
         IIC_Init();
         CH452_Read();
         CH452_Write(CH452_RESET);
     CH452_Write(CH452_SYSON1);
     CH452_Write(CH452_DIG0 | 0x80);
         CH452_Write(CH452_DIG1 | 0x80);
         CH452_Write(CH452_DIG2 | 0x80);
         CH452_Write(CH452_DIG3 | 0x80);
         CH452_Write(CH452_DIG4 | 0x80);
         CH452_Write(CH452_DIG5 | 0x80);
         CH452_Write(CH452_DIG6 | 0x80);
         CH452_Write(CH452_DIG7 | 0x80);
}[/mw_shl_code]
