STM32F7 中断源宏名称 大合集
320|0
 楼主| 稻花香1号 发表于 2018-7-14 17:46 | 显示全部楼层 |阅读模式
typedef enum
/******  Cortex-M7 Processor Exceptions Numbers ****************************************************************/
  NonMaskableInt_IRQn              = -14,    /*!< 2 Non Maskable Interrupt                                          */
  MemoryManagement_IRQn       = -12,    /*!< 4 Cortex-M7 Memory Management Interrupt                           */
  BusFault_IRQn                        = -11,    /*!< 5 Cortex-M7 Bus Fault Interrupt                                   */
  UsageFault_IRQn                     = -10,    /*!< 6 Cortex-M7 Usage Fault Interrupt                                 */
  SVCall_IRQn                           = -5,     /*!< 11 Cortex-M7 SV Call Interrupt                                    */
  DebugMonitor_IRQn                 = -4,     /*!< 12 Cortex-M7 Debug Monitor Interrupt                              */
  PendSV_IRQn                         = -2,     /*!< 14 Cortex-M7 Pend SV Interrupt                                    */
  SysTick_IRQn                         = -1,     /*!< 15 Cortex-M7 System Tick Interrupt                                */
/******  STM32 specific Interrupt Numbers **********************************************************************/
  WWDG_IRQn                   = 0,      /*!< Window WatchDog Interrupt                                         */
  PVD_IRQn                    = 1,      /*!< PVD through EXTI Line detection Interrupt                         */
  TAMP_STAMP_IRQn             = 2,      /*!< Tamper and TimeStamp interrupts through the EXTI line             */
  RTC_WKUP_IRQn               = 3,      /*!< RTC Wakeup interrupt through the EXTI line                        */
  FLASH_IRQn                  = 4,      /*!< FLASH global Interrupt                                            */
  RCC_IRQn                    = 5,      /*!< RCC global Interrupt                                              */
  EXTI0_IRQn                  = 6,      /*!< EXTI Line0 Interrupt                                              */
  EXTI1_IRQn                  = 7,      /*!< EXTI Line1 Interrupt                                              */
  EXTI2_IRQn                  = 8,      /*!< EXTI Line2 Interrupt                                              */
  EXTI3_IRQn                  = 9,      /*!< EXTI Line3 Interrupt                                              */
  EXTI4_IRQn                  = 10,     /*!< EXTI Line4 Interrupt                                              */
  DMA1_Stream0_IRQn           = 11,     /*!< DMA1 Stream 0 global Interrupt                                    */
  DMA1_Stream1_IRQn           = 12,     /*!< DMA1 Stream 1 global Interrupt                                    */
  DMA1_Stream2_IRQn           = 13,     /*!< DMA1 Stream 2 global Interrupt                                    */
  DMA1_Stream3_IRQn           = 14,     /*!< DMA1 Stream 3 global Interrupt                                    */
  DMA1_Stream4_IRQn           = 15,     /*!< DMA1 Stream 4 global Interrupt                                    */
  DMA1_Stream5_IRQn           = 16,     /*!< DMA1 Stream 5 global Interrupt                                    */
  DMA1_Stream6_IRQn           = 17,     /*!< DMA1 Stream 6 global Interrupt                                    */
  ADC_IRQn                    = 18,     /*!< ADC1, ADC2 and ADC3 global Interrupts                             */
  CAN1_TX_IRQn                = 19,     /*!< CAN1 TX Interrupt                                                 */
  CAN1_RX0_IRQn               = 20,     /*!< CAN1 RX0 Interrupt                                                */
  CAN1_RX1_IRQn               = 21,     /*!< CAN1 RX1 Interrupt                                                */
  CAN1_SCE_IRQn               = 22,     /*!< CAN1 SCE Interrupt                                                */
  EXTI9_5_IRQn                = 23,     /*!< External Line[9:5] Interrupts                                     */
  TIM1_BRK_TIM9_IRQn          = 24,     /*!< TIM1 Break interrupt and TIM9 global interrupt                    */
  TIM1_UP_TIM10_IRQn          = 25,     /*!< TIM1 Update Interrupt and TIM10 global interrupt                  */
  TIM1_TRG_COM_TIM11_IRQn     = 26,     /*!< TIM1 Trigger and Commutation Interrupt and TIM11 global interrupt */
  TIM1_CC_IRQn                = 27,     /*!< TIM1 Capture Compare Interrupt                                    */
  TIM2_IRQn                   = 28,     /*!< TIM2 global Interrupt                                             */
  TIM3_IRQn                   = 29,     /*!< TIM3 global Interrupt                                             */
  TIM4_IRQn                   = 30,     /*!< TIM4 global Interrupt                                             */
  I2C1_EV_IRQn                = 31,     /*!< I2C1 Event Interrupt                                              */
  I2C1_ER_IRQn                = 32,     /*!< I2C1 Error Interrupt                                              */
  I2C2_EV_IRQn                = 33,     /*!< I2C2 Event Interrupt                                              */
  I2C2_ER_IRQn                = 34,     /*!< I2C2 Error Interrupt                                              */
  SPI1_IRQn                   = 35,     /*!< SPI1 global Interrupt                                             */
  SPI2_IRQn                   = 36,     /*!< SPI2 global Interrupt                                             */
  USART1_IRQn                 = 37,     /*!< USART1 global Interrupt                                           */
  USART2_IRQn                 = 38,     /*!< USART2 global Interrupt                                           */
  USART3_IRQn                 = 39,     /*!< USART3 global Interrupt                                           */
  EXTI15_10_IRQn              = 40,     /*!< External Line[15:10] Interrupts                                   */
  RTC_Alarm_IRQn              = 41,     /*!< RTC Alarm (A and B) through EXTI Line Interrupt                   */
  OTG_FS_WKUP_IRQn            = 42,     /*!< USB OTG FS Wakeup through EXTI line interrupt                     */
  TIM8_BRK_TIM12_IRQn         = 43,     /*!< TIM8 Break Interrupt and TIM12 global interrupt                   */
  TIM8_UP_TIM13_IRQn          = 44,     /*!< TIM8 Update Interrupt and TIM13 global interrupt                  */
  TIM8_TRG_COM_TIM14_IRQn     = 45,     /*!< TIM8 Trigger and Commutation Interrupt and TIM14 global interrupt */
  TIM8_CC_IRQn                = 46,     /*!< TIM8 Capture Compare Interrupt                                    */
  DMA1_Stream7_IRQn           = 47,     /*!< DMA1 Stream7 Interrupt                                            */
  FMC_IRQn                    = 48,     /*!< FMC global Interrupt                                              */
  SDMMC1_IRQn                 = 49,     /*!< SDMMC1 global Interrupt                                           */
  TIM5_IRQn                   = 50,     /*!< TIM5 global Interrupt                                             */
  SPI3_IRQn                   = 51,     /*!< SPI3 global Interrupt                                             */
  UART4_IRQn                  = 52,     /*!< UART4 global Interrupt                                            */
  UART5_IRQn                  = 53,     /*!< UART5 global Interrupt                                            */
  TIM6_DAC_IRQn               = 54,     /*!< TIM6 global and DAC1&2 underrun error  interrupts                 */
  TIM7_IRQn                   = 55,     /*!< TIM7 global interrupt                                             */
  DMA2_Stream0_IRQn           = 56,     /*!< DMA2 Stream 0 global Interrupt                                    */
  DMA2_Stream1_IRQn           = 57,     /*!< DMA2 Stream 1 global Interrupt                                    */
  DMA2_Stream2_IRQn           = 58,     /*!< DMA2 Stream 2 global Interrupt                                    */
  DMA2_Stream3_IRQn           = 59,     /*!< DMA2 Stream 3 global Interrupt                                    */
  DMA2_Stream4_IRQn           = 60,     /*!< DMA2 Stream 4 global Interrupt                                    */
  ETH_IRQn                    = 61,     /*!< Ethernet global Interrupt                                         */
  ETH_WKUP_IRQn               = 62,     /*!< Ethernet Wakeup through EXTI line Interrupt                       */
  CAN2_TX_IRQn                = 63,     /*!< CAN2 TX Interrupt                                                 */
  CAN2_RX0_IRQn               = 64,     /*!< CAN2 RX0 Interrupt                                                */
  CAN2_RX1_IRQn               = 65,     /*!< CAN2 RX1 Interrupt                                                */
  CAN2_SCE_IRQn               = 66,     /*!< CAN2 SCE Interrupt                                                */
  OTG_FS_IRQn                 = 67,     /*!< USB OTG FS global Interrupt                                       */
  DMA2_Stream5_IRQn           = 68,     /*!< DMA2 Stream 5 global interrupt                                    */
  DMA2_Stream6_IRQn           = 69,     /*!< DMA2 Stream 6 global interrupt                                    */
  DMA2_Stream7_IRQn           = 70,     /*!< DMA2 Stream 7 global interrupt                                    */
  USART6_IRQn                 = 71,     /*!< USART6 global interrupt                                           */
  I2C3_EV_IRQn                = 72,     /*!< I2C3 event interrupt                                              */
  I2C3_ER_IRQn                = 73,     /*!< I2C3 error interrupt                                              */
  OTG_HS_EP1_OUT_IRQn         = 74,     /*!< USB OTG HS End Point 1 Out global interrupt                       */
  OTG_HS_EP1_IN_IRQn          = 75,     /*!< USB OTG HS End Point 1 In global interrupt                        */
  OTG_HS_WKUP_IRQn            = 76,     /*!< USB OTG HS Wakeup through EXTI interrupt                          */
  OTG_HS_IRQn                 = 77,     /*!< USB OTG HS global interrupt                                       */
  DCMI_IRQn                   = 78,     /*!< DCMI global interrupt                                             */
  RNG_IRQn                    = 80,     /*!< RNG global interrupt                                              */
  FPU_IRQn                    = 81,     /*!< FPU global interrupt                                              */
  UART7_IRQn                  = 82,     /*!< UART7 global interrupt                                            */
  UART8_IRQn                  = 83,     /*!< UART8 global interrupt                                            */
  SPI4_IRQn                   = 84,     /*!< SPI4 global Interrupt                                             */
  SPI5_IRQn                   = 85,     /*!< SPI5 global Interrupt                                             */
  SPI6_IRQn                   = 86,     /*!< SPI6 global Interrupt                                             */
  SAI1_IRQn                   = 87,     /*!< SAI1 global Interrupt                                             */
  LTDC_IRQn                   = 88,     /*!< LTDC global Interrupt                                             */
  LTDC_ER_IRQn                = 89,     /*!< LTDC Error global Interrupt                                       */
  DMA2D_IRQn                  = 90,     /*!< DMA2D global Interrupt                                            */
  SAI2_IRQn                   = 91,     /*!< SAI2 global Interrupt                                             */
  QUADSPI_IRQn                = 92,     /*!< Quad SPI global interrupt                                         */
  LPTIM1_IRQn                 = 93,     /*!< LP TIM1 interrupt                                                 */
  CEC_IRQn                    = 94,     /*!< HDMI-CEC global Interrupt                                         */
  I2C4_EV_IRQn                = 95,     /*!< I2C4 Event Interrupt                                              */
  I2C4_ER_IRQn                = 96,     /*!< I2C4 Error Interrupt                                              */
  SPDIF_RX_IRQn               = 97,     /*!< SPDIF-RX global Interrupt                                         */
  DFSDM1_FLT0_IRQn              = 99,     /*!< DFSDM1 Filter 0 global Interrupt                                  */
  DFSDM1_FLT1_IRQn              = 100,    /*!< DFSDM1 Filter 1 global Interrupt                                  */
  DFSDM1_FLT2_IRQn              = 101,    /*!< DFSDM1 Filter 2 global Interrupt                                  */
  DFSDM1_FLT3_IRQn              = 102,    /*!< DFSDM1 Filter 3 global Interrupt                                  */
  SDMMC2_IRQn                 = 103,    /*!< SDMMC2 global Interrupt                                           */
  CAN3_TX_IRQn                = 104,    /*!< CAN3 TX Interrupt                                                 */
  CAN3_RX0_IRQn               = 105,    /*!< CAN3 RX0 Interrupt                                                */
  CAN3_RX1_IRQn               = 106,    /*!< CAN3 RX1 Interrupt                                                */
  CAN3_SCE_IRQn               = 107,    /*!< CAN3 SCE Interrupt                                                */
  JPEG_IRQn                   = 108,    /*!< JPEG global Interrupt                                             */
  MDIOS_IRQn                  = 109     /*!< MDIO Slave global Interrupt                                       */
} IRQn_Type;
