STM32F405的Flash读写异常
557|0
 楼主| 王将 发表于 2018-7-15 13:36 | 显示全部楼层 |阅读模式
使用正点原子的Flash库
现在读写数值永远都不变,麻烦大家帮忙看看是什么情况?
[mw_shl_code=c,true]while (1) {
            static u8 id = 1;
            static u8 cha = 1;
            device_info.Device_id = id++;
            device_info.channel = cha++;
            STMFLASH_Write(FLASH_SAVE_ADDR, (u32*)&device_info, SIZE);
            delay_ms(500);
            //memset(&device_info, '\0', sizeof(struct_device_info));
            device_info.Device_id = 0;
            device_info.channel= 0;
            STMFLASH_Read(FLASH_SAVE_ADDR,(u32*)&device_info, sizeof(struct_device_info));
            print("ID = %d\r\n", device_info.Device_id);
            printf("Channle = %d\r\n", device_info.channel);
            delay_ms(500);
        }[/mw_shl_code]
FLASH_SAVE_ADDR这个改成什么都没用,读出来的数值要么就是255,要么就是一个常数,永远都不变
