[应用相关] 感觉是没进入中断
498|11
 楼主| liuzaiy 发表于 2020-7-4 21:58 | 显示全部楼层 |阅读模式
//初始化配置
void RS485_Init(void)
              USART_InitTypeDef USART_InitStructure;
              NVIC_InitTypeDef NVIC_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//ʹÄÜGPIOA/USARTʱÖÓ
                    RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);//¹¦Äܸ´ÓÃIOʱÖÓʹÄÜ
        USART_Cmd(USART1, ENABLE);//ʹÄÜUSART
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;           //RX½ÓÊÕÒý½Å
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;   //¸¡¿ÕÊäÈë
        GPIO_Init(GPIOA,&GPIO_InitStructure);        //ÅäÖÃ IO
                    GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;           //TX·¢ËÍÒý½Å
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //¸´ÓÃÍÆÍìÊä³ö
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;        //Êä³öËÙ¶È
                    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;             //485¿ØÖÆÒý½Å
              GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;   //ÍÆÍìÊä³ö
              GPIO_Init(GPIOA, &GPIO_InitStructure);
                                GPIO_ResetBits(GPIOA, GPIO_Pin_8);//ĬÈϽÓÊÕģʽ
        USART_ClearFlag(USART1,USART_FLAG_TC);//Çå³ý´®¿Ú´¦Àí±ê־λ
                                USART_ClearITPendingBit(USART1, USART_IT_RXNE);//Çå³ý´®¿ÚÖжϱê־λ
        USART_StructInit(&USART_InitStructure);
                    USART_Init(USART1,&USART_InitStructure);
               USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);        //ÖжÏʹÄÜ
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority =1;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
//中断接收
void USART1_IRQHandler(void)
        u8 RX_dat;
  if(USART_GetITStatus(USART1,USART_IT_RXNE)==SET)//USART_IT_RXNE:????
    RX_dat=USART_ReceiveData(USART1);
    GPIO_SetBits(GPIOA,GPIO_Pin_8);
    delay_ms(1);
    USART_SendData(USART1,RX_dat);
    while(USART_GetFlagStatus(USART1,USART_FLAG_TXE) == RESET){} //???????????
    delay_ms(2);
    GPIO_ResetBits(GPIOA,GPIO_Pin_8);
如题 我之前用串口助手测试232通信 这个测试程序通过了  但换成485通信时(相同串口,只是多了一个控制引脚),程序就实现不了了
zwll 发表于 2020-7-4 22:57 | 显示全部楼层
多看看例程吧,不要在中断里面等待和延时。
dingy 发表于 2020-7-4 23:00 | 显示全部楼层
在接收数据超时或按协议接收完成后,再发送数据。
houcs 发表于 2020-7-4 23:03 | 显示全部楼层
亲 程序流程有问题
ousj 发表于 2020-7-4 23:06 | 显示全部楼层
哪有在中断里使用while的啊
 楼主| liuzaiy 发表于 2020-7-4 23:10 | 显示全部楼层
这是我在网上找的 因为我之前的那个不行
我原来的中断是void USART1_IRQHandler(void)
  if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
        USART1_Buffer[uart_p]=USART_ReceiveData(USART1);
        uart_p++;
接收完后再发送的数据
yufe 发表于 2020-7-4 23:37 | 显示全部楼层
你是直接把232当485来使用,不用加485的芯片吗?
langgq 发表于 2020-7-4 23:42 | 显示全部楼层
是不是有多个中断,看中断组的配置是否合理
huanghuac 发表于 2020-7-4 23:45 | 显示全部楼层
之前遇到的问题好像是中断配置的有问题
songqian17 发表于 2020-7-4 23:49 | 显示全部楼层
还有就是串口中断函数里放了串口打印函数
llljh 发表于 2020-7-5 09:53 | 显示全部楼层
中断不要延时啊,,,,,
 楼主| liuzaiy 发表于 2020-7-5 09:56 | 显示全部楼层
哦,那我就知道怎么回事了,多谢大家
