关于STM32 进入STOP模式问题,求求各位大神帮忙看看
646|0
 楼主| qwepk120 发表于 2020-7-14 15:26 | 显示全部楼层 |阅读模式
使用的是STM32L073芯片
根据例程代码中
在进入停止模式之前进入了
static void SystemPower_Config(void)
  GPIO_InitTypeDef GPIO_InitStructure = {0};
  /* Enable Power Control clock */
  __HAL_RCC_PWR_CLK_ENABLE();
  /* Enable Ultra low power mode */
  HAL_PWREx_EnableUltraLowPower();
  /* Enable the fast wake up from Ultra low power mode */
  HAL_PWREx_EnableFastWakeUp();
  /* Enable GPIOs clock */
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOE_CLK_ENABLE();
  /* Configure all GPIO port pins in Analog Input mode (floating input trigger OFF) */
  /* Note: Debug using ST-Link is not possible during the execution of this   */
  /*       example because communication between ST-link and the device       */
  /*       under test is done through UART. All GPIO pins are disabled (set   */
  /*       to analog input mode) including  UART I/O pins.           */
  GPIO_InitStructure.Pin = GPIO_PIN_All;
  GPIO_InitStructure.Mode = GPIO_MODE_ANALOG;
  GPIO_InitStructure.Pull = GPIO_NOPULL;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStructure);
  HAL_GPIO_Init(GPIOB, &GPIO_InitStructure);
  HAL_GPIO_Init(GPIOC, &GPIO_InitStructure);
  HAL_GPIO_Init(GPIOD, &GPIO_InitStructure);
  HAL_GPIO_Init(GPIOH, &GPIO_InitStructure);
  HAL_GPIO_Init(GPIOE, &GPIO_InitStructure);
  /* Disable GPIOs clock */
  __HAL_RCC_GPIOA_CLK_DISABLE();
  __HAL_RCC_GPIOB_CLK_DISABLE();
  __HAL_RCC_GPIOC_CLK_DISABLE();
  __HAL_RCC_GPIOD_CLK_DISABLE();
  __HAL_RCC_GPIOH_CLK_DISABLE();
  __HAL_RCC_GPIOE_CLK_DISABLE();
但是程序就卡死在了这里,无法继续发送数据等工作
有写初始化,取消这个函数就可以正常跑起来,但是电流过大,无法达到低功耗效果
