请问这个函数指针怎么理解
270|0
 楼主| 大碴子味 发表于 2018-7-27 13:08 | 显示全部楼层 |阅读模式
static void (* _GetDevFunc(GUI_DEVICE ** ppDevice, int Index))(void) {
  GUI_USE_PARA(ppDevice);
  switch (Index) {
  case LCD_DEVFUNC_SET_VRAM_ADDR:
    return (void (*)(void))_SetVRAMAddr;
  case LCD_DEVFUNC_SET_VSIZE:
    return (void (*)(void))_SetVSize;
  case LCD_DEVFUNC_SET_SIZE:
    return (void (*)(void))_SetSize;
  case LCD_DEVFUNC_INIT:
    return (void (*)(void))_Init;
  case LCD_DEVFUNC_ON:
    return (void (*)(void))_On;
  case LCD_DEVFUNC_OFF:
    return (void (*)(void))_Off;
  case LCD_DEVFUNC_SETLUTENTRY:
    return (void (*)(void))_SetLUTEntry;
  return NULL;
