用F407的官方库初始化各个始终都是多少啊????
327|0
 楼主| 车水马龙 发表于 2018-7-31 11:58 | 显示全部楼层 |阅读模式
  *        Supported STM32F4xx device revision    | Rev A
  *        System Clock source                    | PLL (HSE)
  *        SYSCLK(Hz)                             | 168000000
  *        HCLK(Hz)                               | 168000000
  *        AHB Prescaler                          | 1
  *        APB1 Prescaler                         | 4
  *        APB2 Prescaler                         | 2
  *        HSE Frequency(Hz)                      | 25000000
  *        PLL_M                                  | 25
  *        PLL_N                                  | 336
  *        PLL_P                                  | 2
  *        PLL_Q                                  | 7
  *        PLLI2S_N                               | NA
  *        PLLI2S_R                               | NA
  *        I2S input clock                        | NA
  *        VDD(V)                                 | 3.3
  *        Main regulator output voltage          | Scale1 mode
  *        Flash Latency(WS)                      | 5
  *        Prefetch Buffer                        | OFF
  *        Instruction cache                      | ON
  *        Data cache                             | ON
  *        Require 48MHz for USB OTG FS,          | Enabled
  *        SDIO and RNG clock                     |                                 什么意思
