新手求救个时钟问题
1521|1
 楼主| sdaofang 发表于 2011-12-30 23:07 | 显示全部楼层 |阅读模式
自己编了个简单的时钟程序,用数码官显示的,可是显示结果错误了,数码官的E脚老是亮着,小弟不知道是什么原因请大虾们帮忙看看解决下啊~~在这谢谢了~~~~
#include<reg51.h>
#include<intrins.h>
#define uchar unsigned char
#define uint unsigned int
uchar code Disp_Tab[] = {0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90,0xbf};
uchar code dispbit[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdF,0xbF,0x7F};
uchar code write_add[]={0x8c,0x8a,0x88,0x86,0x84,0x82,0x80};
uchar code red_add[]={0x8d,0x8b,0x89,0x87,0x85,0x83,0x81};
uchar  time_dat[]={10,5,12,25,0,0,0};
uchar  disp_dat[8];
sbit sck=P3^4;
sbit io=P3^5;
sbit rst=P3^6;
uchar red_byte();
uchar red_ds1302(uchar add);
void write_byte(uchar dat);
void write_ds1302(uchar add,uchar dat);
void set_time();
void red_time();
void pros();
void disply();
void delay(unsigned int i);
uchar i;
for(i=0;i<8;i++)
  sck=0;
  _nop_();
  io=dat&0x01;
  dat=dat>>1;
  sck=1;
  _nop_();
rst=0;
_nop_();
sck=0;
_nop_();
rst=1;
_nop_();
write_byte(add);
write_byte(dat);
sck=1;
_nop_();
io=1;
rst=0;
_nop_();
unsigned char red_byte()
uchar i,temp;
for(i=0;i<8;i++)
  sck=0;
  _nop_();
  temp=temp>>1;
  if(io)
  temp=temp|0x80;
  sck=1;
  _nop_();
return (temp);
unsigned char red_ds1302(uchar add)
uchar temp;
rst=0;
_nop_();
sck=0;
_nop_();
rst=1;
_nop_();
write_byte(add);
temp=red_byte();
sck=1;
_nop_();
io=1;
rst=0;
_nop_();
return(temp);
void set_time()
uchar i,j;
for(i=0;i<7;i++)
  j=time_dat[i]/10;
  time_dat[i]=time_dat[i]%10;
  time_dat[i]=time_dat[i]+j*16;
write_ds1302(0x8e,0x00);
for(i=0;i<7;i++)
  write_ds1302(write_add[i],time_dat[i]);
write_ds1302(0x8e,0x80);
void red_time()
uchar i;
for(i=0;i<7;i++)
  time_dat[i]=red_ds1302(red_add[i]);
void pros()
disp_dat[0]=time_dat[6]%16;
disp_dat[1]=time_dat[6]/16;
disp_dat[2]=10;
disp_dat[3]=time_dat[5]%16;
disp_dat[4]=time_dat[5]/16;
disp_dat[5]=10;
disp_dat[6]=time_dat[4]%16;
disp_dat[7]=time_dat[4]/16;
void disply()
uchar i;
P0=0xff;
for(i=0;i<8;i++)
  P0=Disp_Tab[disp_dat[i]];
  P1=dispbit[i];
  delay(10);
    uint j;
    for(i; i > 0; i--)
    for(j = 100; j > 0; j--);
void main()
  set_time();
  while(1)
  red_time();
  pros();
  disply();
