[应用相关] ucos移植到STM32上编译错误
820|12
 楼主| liuzaiy 发表于 2020-7-26 18:33 | 显示全部楼层 |阅读模式
我已添加ucos-ii.h和os_cpu_a.asm,编译时显示如下错误,请大家帮忙看一下问题出在哪里?
ucos.axf: Error: L6218E: Undefined symbol OSPrioCur (referred from os_cpu_a.o).
ucos.axf: Error: L6218E: Undefined symbol OSPrioHighRdy (referred from os_cpu_a.o).
ucos.axf: Error: L6218E: Undefined symbol OSRunning (referred from os_cpu_a.o).
ucos.axf: Error: L6218E: Undefined symbol OSTCBCur (referred from os_cpu_a.o).
ucos.axf: Error: L6218E: Undefined symbol OSTCBHighRdy (referred from os_cpu_a.o).
ucos.axf: Error: L6218E: Undefined symbol OSIntExit (referred from os_cpu_c.o).
ucos.axf: Error: L6218E: Undefined symbol OSIntNesting (referred from os_cpu_c.o).
ucos.axf: Error: L6218E: Undefined symbol OSTimeTick (referred from os_cpu_c.o).
ucos.axf: Error: L6218E: Undefined symbol OS_CPU_SysTickClkFreq (referred from os_cpu_c.o).
ucos.axf: Error: L6218E: Undefined symbol OSLockNesting (referred from os_task.o).
ucos.axf: Error: L6218E: Undefined symbol OSRdyGrp (referred from os_task.o).
ucos.axf: Error: L6218E: Undefined symbol OSRdyTbl (referred from os_task.o).
ucos.axf: Error: L6218E: Undefined symbol OSTCBFreeList (referred from os_task.o).
ucos.axf: Error: L6218E: Undefined symbol OSTCBList (referred from os_task.o).
ucos.axf: Error: L6218E: Undefined symbol OSTCBPrioTbl (referred from os_task.o).
ucos.axf: Error: L6218E: Undefined symbol OSTaskCtr (referred from os_task.o).
ucos.axf: Error: L6218E: Undefined symbol OS_Dummy (referred from os_task.o).
ucos.axf: Error: L6218E: Undefined symbol OS_MemCopy (referred from os_task.o).
ucos.axf: Error: L6218E: Undefined symbol OS_Sched (referred from os_task.o).
ucos.axf: Error: L6218E: Undefined symbol OS_StrCopy (referred from os_task.o).
ucos.axf: Error: L6218E: Undefined symbol OS_StrLen (referred from os_task.o).
ucos.axf: Error: L6218E: Undefined symbol OS_TCBInit (referred from os_task.o).
ucos.axf: Error: L6218E: Undefined symbol OSTime (referred from os_time.o).
Target not created
dingy 发表于 2020-7-26 18:38 | 显示全部楼层
好像是说的重定义
houcs 发表于 2020-7-26 18:40 | 显示全部楼层
看看路径添加好了么
该包含的头文件都包含了么
kangzj 发表于 2020-7-26 18:50 | 显示全部楼层
在UCOS_ii.h中定义了 OS_EXT  INT8U             OSPrioCur;
在os_cpu_a.asm中定义了 EXTERN  OSPrioCur
这两个文件我都已添加到工程中
yufe 发表于 2020-7-26 18:53 | 显示全部楼层
编译元件中头文件路径有没有设置好
zhuhuis 发表于 2020-7-26 18:57 | 显示全部楼层
头文件路径已加,要是头文件没有加入,会提示打不开头文件的呀
chuxh 发表于 2020-7-26 19:02 | 显示全部楼层
在哪个文件里添加UCOS_ii.h?
jiajs 发表于 2020-7-26 19:09 | 显示全部楼层
一步一步做不会错的
juventus9554 发表于 2020-7-26 20:17 | 显示全部楼层
后面自己学懂了,再回头来学内核的原理
supernan 发表于 2020-7-26 20:21 | 显示全部楼层
我觉得先回用更重要
morrisk 发表于 2020-7-26 20:27 | 显示全部楼层
重新定义一下
 楼主| liuzaiy 发表于 2020-7-26 21:46 | 显示全部楼层
哦,那我就知道怎么回事了,多谢大家
Margon 发表于 2020-10-22 22:21 | 显示全部楼层
文件路径问题
