STM32H7的FMC做纯软件IO输出控制可以输出40MHz方波
394|0
3月的尾巴|  楼主 | 2018-8-10 07:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
FMC时序配置为最高性能:
SRAM_Timing.AddressSetupTime       = 0;
        SRAM_Timing.AddressHoldTime        = 1;
        SRAM_Timing.DataSetupTime          = 1;
        SRAM_Timing.BusTurnAroundDuration  = 0;
        SRAM_Timing.CLKDivision            = 2;
        SRAM_Timing.DataLatency            = 0;
        SRAM_Timing.AccessMode             = FMC_ACCESS_MODE_A;
        hsram.Init.NSBank             = FMC_NORSRAM_BANK1;
        hsram.Init.DataAddressMux     = FMC_DATA_ADDRESS_MUX_DISABLE;
        hsram.Init.MemoryType         = FMC_MEMORY_TYPE_SRAM;
        hsram.Init.MemoryDataWidth    = FMC_NORSRAM_MEM_BUS_WIDTH_32;
        hsram.Init.BurstAccessMode    = FMC_BURST_ACCESS_MODE_DISABLE;
        hsram.Init.WaitSignalPolarity = FMC_WAIT_SIGNAL_POLARITY_LOW;
        hsram.Init.WaitSignalActive   = FMC_WAIT_TIMING_BEFORE_WS;
        hsram.Init.WriteOperation     = FMC_WRITE_OPERATION_ENABLE;
        hsram.Init.WaitSignal         = FMC_WAIT_SIGNAL_DISABLE;
        hsram.Init.ExtendedMode       = FMC_EXTENDED_MODE_DISABLE;
        hsram.Init.AsynchronousWait   = FMC_ASYNCHRONOUS_WAIT_DISABLE;
        hsram.Init.WriteBurst         = FMC_WRITE_BURST_DISABLE;
        hsram.Init.ContinuousClock    = FMC_CONTINUOUS_CLOCK_SYNC_ONLY;
