发现HAL库没有专门的外部中断EXTI文件了,整合到GPIO里面
285|0
 楼主| 没名字的人 发表于 2018-8-10 17:50 | 显示全部楼层 |阅读模式
HAL库的EXTI整的真简单,直接合并到GPIO配置里面了。
1、初始化实现地区是方便了不少
  * @brief  Configures EXTI lines 15 to 10 (connected to PC.13 pin) in interrupt mode
  * @param  None
  * @retval None
static void EXTI15_10_IRQHandler_Config(void)
  GPIO_InitTypeDef   GPIO_InitStructure;
  /* Enable GPIOC clock */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  /* Configure PC.13 pin as input floating */
  GPIO_InitStructure.Mode = GPIO_MODE_IT_FALLING;
  GPIO_InitStructure.Pull = GPIO_NOPULL;
  GPIO_InitStructure.Pin = GPIO_PIN_13;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStructure);
  /* Enable and set EXTI lines 15 to 10 Interrupt to the lowest priority */
  HAL_NVIC_SetPriority(EXTI15_10_IRQn, 2, 0);
  HAL_NVIC_EnableIRQ(EXTI15_10_IRQn);
