[电源] 125W立体声HD数字输入功率放大方案
2344|0
 楼主| kakio 发表于 2012-1-4 07:45 | 显示全部楼层 |阅读模式
TI 公司的TAS5612是 125W立体声/250W单声道PurePath™HD数字输入功率放大级,集成了闭环反馈(PurePath™ HD)的高性能模拟输入D类放大器,能从32.5V单电源中向4-8欧姆扬声器提功125W立体声.信号带宽达成80kHz,1W 4欧姆的THD为0.03%,PSRR为80dB,SNR大于100dB.主要用于家庭影院,AV接收器,DVD/蓝光光盘接收器等.本文介绍TAS5612主要特性, 功能方框图, 典型系统框图以及多种应用电路.
TAS5612:125W STEREO / 250W MONO PurePath™ HD DIGITAL-INPUT POWER STAGE
The TAS5612 is a high performance analog input Class D amplifier with integrated closed loop feedback technology (known as PurePath™ HD) with the ability to drive up to 125W(1) Stereo into 4 to 8 Speakers from a single 32.5V supply.
PurePath™ HD technology enables traditional AB-Amplifier performance (<0.03% THD) levels while providing the power efficiency of traditional class D amplifiers.
Unlike traditional Class D amplifiers, the distortion curve only increases once the output levels move into clipping.
PurePath™ HD technology enables lower idle losses making the device even more efficient.
TAS5612主要特性:
PurePath™ HD Enabled Integrated Feedback Provides: Signal Bandwidth up to 80kHz for High Frequency Content From HD Sources Ultralow 0.03% THD at 1W into 4 Flat THD at all Frequencies for Natural Sound 80dB PSRR (BTL, No Input Signal) >100dB (A weighted) SNR Click and Pop Free Startup
Pin compatible with TAS5631, TAS5616 and TAS5614
Multiple Configurations Possible on the Same PCB With Stuffing Options: Mono Parallel Bridge Tied Load (PBTL) Stereo Bridge Tied Load (BTL) 2.1 Single Ended Stereo Pair and Bridge Tied Load Subwoofer
Total Output Power at 10%THD+N 250W in Mono PBTL Configuration 125W per Channel in Stereo BTL Configuration
Total Output Power in BTL configuration at 1%THD+N
130W Stereo into 3
105W Stereo into 4
70W Stereo into 6
55W Stereo into 8
TAS5612主要应用:
• Home Theater Systems
• AV Receivers
• DVD/ Blu-ray Disc™ Receivers
• Mini Combo Systems
• Active Speakers and Subwoofers
图1.TAS5612功能方框图
图2.典型系统框图
图3.带BD调制滤波器的TAS5612差分(2N)BTL应用电路图
图4.带BD调制滤波器的TAS5612 (2N)PBTL应用电路图
